Go to Post Free food attracts us like flies. It's the one sure way to get us to meetings. - Mark McLeod [more]
Unread 06-02-2005, 12:47
Aidan F. Browne's Avatar Unsung FIRST Hero
Aidan F. Browne Aidan F. Browne is offline
Engineer
AKA: The Aidan-bot
Aidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond repute
Question Analog / Digital IO Connectors
What methods have teams used for physically connecting to the Analog and Digital ports on the RC?
I seem to remember a drawing that showed the pin spacing, but I can't find it at IFI. I also remember some discussion on CD at one point, but I can't find that either... maybe I'm just having one of those days.
(I don't have immediate access to an RC or I would measure... )
Any tips would be appreciated -- Thanks!
Aidan
Unread 06-02-2005, 13:02
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: Analog / Digital IO Connectors
We take old speed controller data cables and snip off the male end, and then solder on whatever we need.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 06-02-2005, 13:32
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Yep... cutting PWM cables is the easiest way. They are a bit pricey at $5 a piece from IFI, but they seem more reliable than putting something together by hand.
As far as the connector size, I'm almost certain that the pins are .100" spaced. Anyone wanna verify this, in case I too am having one of those days?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 06-02-2005, 21:50
I'll confirm the .1" spacing on the pins.
We build our own cables usually with the standard hobby connectors and covers. This year we're using individual covers during the build, but switching the cables/connectors to block covers the last week.
Unread 06-02-2005, 22:26
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
I would disagree on spliced cables being more reliable. With the right tools and parts you can make cables equal in quality to IFI's cables.
You pretty much have 3 or 4 choices on connectors - Molex, AMP, standard Servo type, and IDC type. The IDC tyle require no special tools (although they are designed for use with a real punchdown tool), and are great for prototyping but i would not recommend them for competition use. I've found the AMP housings to be too large sideways, and the servo connectors are more expensive than they should be, therefore we use the molex ones. You can do a search for the part #, I believe they are something like c-grid SL. The only problem with them are the male pins are longer than standard JR servo cables. (But you wont use the male pins for connecting to the analog/digital IO's, only if you make your own PWM cables)
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
Dynamic Input/Output Changing Paolo Control System 6 23-09-2004 19:09
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
digital i/o connectors Mercutio Electrical 4 19-01-2004 19:20
