Go to Post Nerds do whatever they want to do, and they do it with style. - EricVanWyk [more]
Unread 06-02-2005, 13:18
hawk_11's Avatar
hawk_11 hawk_11 is offline
FIRST Survivor
None #9999
hawk_11 is an unknown quantity at this point
Need help with code.
Hello, I'm a beginner programmer on Team 1302. I need help with a simple code.
The story runs like this. Today I was asked to make a very simple code to just make the motors rotate. I then realized that my mentors/other programmers never taught me how to start a program. This is really bad because I've been almost the only programmer here all build season. Long story short, I plugged the code in, but it is saying I'm missing a source code. Guess what, I was never told about source codes and seeing as it has the word 'source' in it, you'd think someone would remember to teach me -.- Can anyone help?
Unread 06-02-2005, 13:20
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: Need help with code.
What do you mean you "plugged the code in"? Do you have the latest MPLab IDE and compiler on your computer?
http://www.mikesorrenti.com/
Unread 06-02-2005, 13:22
D.J. Fluck
Posts: n/a
More specific FIRST related coding help
http://www.chiefdelphi.com/forums/sh...ad.php?t=30976
http://www.chiefdelphi.com/forums/sh...ad.php?t=31817
http://www.ifirobotics.com/rc.shtml#Programming
If you have no experience with C try this white paper
http://www.chiefdelphi.com/forums/pa...le&paperid=396
There are plenty of tutorials and help all around this forum if you just search and look around. Hope these help
Unread 06-02-2005, 13:25
hawk_11's Avatar
FIRST Survivor
None #9999
yes
Unread 06-02-2005, 13:28
hawk_11's Avatar
FIRST Survivor
None #9999
thanks
Unread 06-02-2005, 13:31
Anton's Avatar
Anton Anton is offline
Anton Povzner
#1581 (Element)
Anton can only hope to improve
you should download the default code from ifirobotics.com/rc.shtml
fo to file>>open workspase>> the only *mcp file in the code folder and then just modify default_routie(found in user_routines.c) as you need.
to access motors give a value between 0 and 255 to a pwm port where the motor is plugged in.
pwm01=255; for example
Unread 06-02-2005, 13:56
hawk_11's Avatar
FIRST Survivor
None #9999
thanks, actually I found out what I was doing wrong fifteen seconds ago so this post is now effectively dead.
Thanks for the help everyone!
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
