Go to Post Sounds like a silly idea... so of course I'm in. - George1902 [more]
Unread 06-02-2005, 16:34
whakojacko's Avatar
whakojacko whakojacko is offline
FRC #1072 (hrt)
whakojacko is on a distinguished road
Send a message via AIM to whakojacko Send a message via MSN to whakojacko
Re: Have you gotten your robot to go towards the vision tetra?
Originally Posted by Sunjit
We've also been able to make our practic bot go towards the vision tetra and stop.
AAah stopping... were still trying to get that part to work reliably.
Harker Robotics:1072
http://www.harker-robotics.org
Unread 06-02-2005, 16:43
Update: 195 Test-a-bot now succesfully finds a vision tetra within a 180 degree field of view, drives to it (quite fast, too), and stops 6 inches away, every time.
Whats next?
Unread 07-02-2005, 15:31
mikesown mikesown is offline
mikesown is an unknown quantity at this point
I'm kinda new to programming in c, and i have a question: what is between 120 and 134 for cam.pan_servo, and what is cam.pan_servo?
Additionally, what would you recommend I read up on to become proficent at programming in c?
Thanks,
Mike
Unread 20-02-2005, 20:51
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
We can consistently get a vision tetra and raise our arm. About 80% of the time we can drive to the goal, and stack about 30% of the time. Some minor tweaking should bring these numbers up alot
http://www.mikesorrenti.com/
Unread 21-02-2005, 22:18
neilsonster's Avatar
neilsonster neilsonster is offline
AKA: Andrew Neilson
FRC #0772 (Sabre Bytes)
neilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to all
Send a message via MSN to neilsonster
For ours at this point it tracks and picks up a vision tetra consistently then looks for the goal.. Unfortunately at crunch time the mechanical had lots of work to do on the robot and I lost the time I needed to fine tune :/. Hopefully it'll be able to cap by the second competition O_O.
Unread 25-02-2005, 20:18
kokodabear's Avatar
kokodabear kokodabear is offline
HELP!
AKA: Brady
#0686 (Bovine Intervention)
kokodabear is an unknown quantity at this point
Send a message via AIM to kokodabear
In regards to what the camera code will do with 2 tetras in sight, I believe I read that it will track the object with the largest bounding box (or closest tetra). However, by default, it will track the first thing it sees (such as another team's tetra). This is what we're doing:
1: Pan left and right while at a standstill.
2: Record the pan angle that located the largest amount of green.
3: Rotate accordingly and head forward.
NOTE: If you have to keep turning, your teammate may have that tetra...
5: When the bounding box is big enough stop, pick it up.
7: Relying on the starting position, and the initial turn from step 2, turn to the center goal (unless you dont want to cap the center).
8: Begin tracking yellow.
9: When the bounding box is big enough, stack.
10: Ungrab and backout.
11: Track a loading station?
Who needs drivers? Lets have a COMPLETELY autonomous robot!
Q/A questions so far.. AmyPrib Rules/Strategy 49 28-01-2005 08:39
Wolrd Triple Play Autonomous Mode (WAM) Standards Natchez General Forum 3 11-01-2005 15:52
Can an a robot take a tetra from another robot in their allinace? Koko Ed Rules/Strategy 3 10-01-2005 23:01
Vision Tetra Alignment Issues phrontist Rules/Strategy 8 10-01-2005 20:56
Just where are vision "bonus" tetras placed? David Brinza Rules/Strategy 17 10-01-2005 20:50
