Go to Post Every robot needs a locky-thingy. A robot without one might fire when it isn't supposed to, and hit the wrong target; e.g., a referee, FTA, or robot inspector. - Richard Wallace [more]
Unread 06-02-2005, 19:13
DAN THE MAN DAN THE MAN is offline
DAN THE MAN is an unknown quantity at this point
Accelerometer Wiring/Input
I wired up the accelerometer to a pwm cable attaching the same colour wires of the pwm to the accelerometer because that seemed to be the logical thing to do. The input that is recieved from the command (Get_Analog_Value(rc_ana_in02)) say constand regardless of what ever you do with the accelerometer ie. move it back and forth. The value is 834, i was just wondering if anyone has had a simular problem or if I'm doing something wrong.
Thanks
Unread 06-02-2005, 20:02
Re: Accelerometer Wiring/Input
It's a good idea to read the documentation before you wire things, and to search before you post.
http://www.chiefdelphi.com/forums/sh...r+wir e+color
The cable provided in the kit of parts uses a non-standard
color coding for power. Connect the black wire to +5V and
the red wire to ground. The white wire connects to the RC's
analog input.
Some things i'm trying to understand on Kevin's Accelerometer Code Squall Programming 2 03-02-2005 12:01
Accelerometer Tom McCurdy Programming 5 30-01-2005 23:45
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
Example accelerometer code released. Kevin Watson Programming 0 20-01-2005 03:45
Using Accelerometer with '04 controller sanddrag Control System 4 20-02-2004 12:18
