Go to Post Ok, so you are going to use a robot to hold all of those rivets together? - gblake [more]
Unread 02-02-2005, 18:47
harsh harsh is offline
harsh is an unknown quantity at this point
How do you animate grass and wheels?
When using 3DS MAX, how do you create grass, and make wheels move during animation. We have managed to make the robot move, but the wheels just slide. Also, we were wondering how to rotate motors on the wheels.
Unread 03-02-2005, 00:17
rowe rowe is offline
Eric Rowe
FRC #1097 (Site 3 Engineering)
rowe has a spectacular aura aboutrowe has a spectacular aura about
Send a message via AIM to rowe Send a message via MSN to rowe Send a message via Yahoo to rowe
Re: How do you animate grass and wheels?
To animate the wheels, you should make sure the pivot point is in the middle. Select the 3rd or 4th tab on your right control panel (forgive me if I'm wrong, I'm working from memory). Click the "affect pivot only" button and then click the "center pivot to object," taht should align it. Then animate the wheel by rotating and using keyframes (the same way you animated the robot, only with the rotate tool instead of the move tool). The grass will be harder, I've never tried so i don't have an easy solution. I can try to set you in the right direction though, unless its going to be up close, use a texture instead of modeling.
Eric Rowe | Alumn
Team 1097 | Site 3 Engineering
2005 Silicon Valley Regional Finalists
2005 Silicon Valley Regional Sportsmanship Award
2005 Sacramento Regional Finalists
2005 Sacramento Regional Sportsmanship Award
2004 Silicon Valley Regional Sportsmanship Award
2004 Sacramento Regional Visualization Award
2004 Sacramento Regional Engineering Inspiration Award
Unread 03-02-2005, 01:02
Mike Ciance Mike Ciance is offline
FRC #0025 (Raider Robotix)
Mike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant future
Send a message via AIM to Mike Ciance
the easiest way to create grass would be with the hairfx plugin
Unread 06-02-2005, 22:42
Eric Rowe
Unfortunately, most teams don't have $600 to spend for a plug-in. I still haven't thought of a way to do this, but I'd be interested if anyone has an easy solution to do this.
Eric Rowe | Alumn
Unread 06-02-2005, 23:39
MConte05's Avatar
MConte05 MConte05 is offline
"Operation FIRST"
AKA: Matt Conte
#1098 (G.I.'s)
Team Role: Driver
MConte05 is on a distinguished road
Send a message via AIM to MConte05
http://67.15.36.49/ffa/tutorials/max/grass/grass1.asp
A tutorial that is specifically geared towards animating grass in 3dsmax.
Hope it helps.
Unread 07-02-2005, 15:11
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
You can make the grass as mesh objects and then use an animated wave deformation to animate the waving grass... for rotating wheel i would actually suggest using a float expression assigned as the rotation motion controller and typing an expression... read up on how to do that...
Unread 07-02-2005, 23:04
Tristan116 Tristan116 is offline
3dsMax Deity
#0116 (Epsilon Delta)
Team Role: Animator
Tristan116 is an unknown quantity at this point
Send a message via AIM to Tristan116
There is a great free hair plugin called Ornatrix. It just went public, but you can still get the "beta" version http://www.ibmr.net/Ornatrix/
Anyways, it's great for grass too. It's pretty easy to figure out as well. Great forum on their site for questions and the such.
Here is what i did as a test using this plug in a while ago.
http://www.chiefdelphi.com/forums/at...tid=2921&stc=1
Well, Enjoy.
Name:	glamdring orna test.jpg
Unread 10-02-2005, 23:59
FRC #0701 (RoboVikes)
DANG tristan that is impressive... more the plugins fault but still that is very nice ... 116 aniamtions are always of very high caliber... but u didn't submit one last year right?
Team 701
Unread 12-02-2005, 09:50
3dsMax Deity
Team Role: Animator
We did, it was quite the cool.
http://web.mit.edu/~levpopov/Public/116_AVA2004.mov
Enjoy.
Unread 12-02-2005, 09:55
SteveC116's Avatar
SteveC116 SteveC116 is offline
SteveC116 has a spectacular aura aboutSteveC116 has a spectacular aura about
Thanks for the compliment Salik!
*Guarana Induced Happiness*
Steve Cohen
Team 116 Animation Captain
http://stevecohen.blogspot.com
