Go to Post I think this is as close as we'll come to getting that water game we've been waiting for. - Jeff Rodriguez [more]
Unread 03-02-2005, 19:40
flounder22001's Avatar
flounder22001 flounder22001 is offline
flounder22001 is an unknown quantity at this point
32k controller limit
whenever i intialize _USE_CMU_CAMERA to be able to use the camera the .hex file size goes to 60k and the controller's limit is 32k
if anyone else has had this problem and has found a way around it , it would be really nice if you caould help us.
Unread 03-02-2005, 19:46
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Re: 32k controller limit
I was just wondering whose CMU cam code you are using? The official IFI code?
- from B B frank
Unread 03-02-2005, 19:58
whakojacko's Avatar
whakojacko whakojacko is offline
FRC #1072 (hrt)
whakojacko is on a distinguished road
Send a message via AIM to whakojacko Send a message via MSN to whakojacko
i never looked at the size, but ive been turning on and off that macro for testing stuff and its always loaded fine
Harker Robotics:1072
http://www.harker-robotics.org
Unread 03-02-2005, 20:05
i'm using the official default code supplied by first (or ifi)
whackjacko: can you check the size of the .hex file with the macro on and tell me what it is?
Unread 03-02-2005, 20:32
AIBob's Avatar
AI Programmer
To look at what is filling up your 32KB, you can just loop at the .map file....
if that is not there, then you can produce it by going to:
Project -> Build Options... -> Project :::::: <MPLINK Linker> Check "Generate map file"
- from B B frank
Unread 03-02-2005, 21:22
Originally Posted by flounder22001
whenever i intialize _USE_CMU_CAMERA to be able to use the camera the .hex file size goes to 60k and the controller's limit is 32k.
The file size is not the same thing as the code size. The .hex file contains more than just the raw bits which end up in the flash memory of the controller. Look in the .map file to find out how much space the program is actually taking.
Unread 04-02-2005, 18:48
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Indeed. It's in Intel-Hex (google for it if you really want to know). Mine is 69 KB, but the MAP file says that the code is using 72% of my program memory (or 24K).
Unread 05-02-2005, 14:10
Don Reid Don Reid is offline
Don Reid will become famous soon enough
We saw this after trying to combine the Navigation code and the camera code. I noticed that the default project settings turn off a lot of the optimizations the compiler can do, resulting in larger slower code. This may be needed for the simulator or a debugger, but without them the code was 1/2 the size.
I also saw that the largest module was vprintf (~4k). If you get rid of all printf calls, this will go away. You can sill use puts(), itoa(), ltoa() ... which are smaller.
Of course there is no substitute for going through the code and removing anything you don't need. Some of the sample code could be made smaller and faster (but probably less readable) too.
Don Reid
Unread 06-02-2005, 09:26
Plloyd Plloyd is offline
Plloyd is an unknown quantity at this point
Thanks guys, this discussion is very helpful... to many more than just myself I am certain.
However, I am still confused about how we can use external memory, and the consequences of doing that (runs slower?)
Also, how do you modify the optimization settings of the project?
Thanks,
Plloyd
Unread 07-02-2005, 00:01
There is a tool on the MPLAB toolbar for the build options, or find it under
the Project menu. There is a line like this:
-D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
The -O*- settings are turning off various optomizations. Remove them
to turn things back on.
Don Reid
Speed controllers won't communicate w/robot controller steven114 Control System 12 03-02-2005 21:26
Robot Controller File Size Limit ?? RoboGeek Programming 1 17-01-2005 19:59
2003 robot controller & interface LGuY Control System 3 04-04-2004 16:01
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
