#16
Re: Default code and the Compressor
Keep in mind that you're not supposed to run the compressor backwards - make sure that, if you have the spike in reverse, you switch the leads on the compressor or something.
#17
yeah, mine won't work either. much more importantly, 2.4 won't even take input from our joysticks, yet 2.2 will. these are both unmodified. any suggestions?
| Help On Coding 2K1 Controller | GregTheGreat | Programming | 9 | 05-12-2003 18:35 |
| Chassis Material/Construction | sanddrag | Technical Discussion | 51 | 05-12-2003 12:59 |
| New software?? | mjt902 | Programming | 2 | 08-01-2003 10:40 |
| PBASIC 2.5 answer from Parallax | JasonS | Programming | 6 | 07-01-2003 19:21 |
| Team 237 unleashes a "Beast" | Elgin Clock | Robot Showcase | 5 | 27-03-2002 21:09 |
