Go to Post I'm very certain that specifics are quite interesting but all that keeps going through my mind is, "OOOOOH SHINY!" - Andrew Schreiber [more]
Unread 07-02-2005, 14:50
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Error: Unable to locate 'stdio.h'
I'm trying to compile the default camera code, and getting the following error:
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "main.c" -fo="main.o" /i"C:\mcc18\h" -D_FRC_BOARD -D_USE_CMU_CAMERA -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "user_SerialDrv.c" -fo="user_SerialDrv.o" /i"C:\mcc18\h" -D_FRC_BOARD -D_USE_CMU_CAMERA -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
C:\robo-code\alpha\user_SerialDrv.c:30: unable to locate 'stdio.h'
error 1 spawning C:\mcc18\bin\cpp18
Halting build on first failure as requested.
BUILD FAILED: Mon Feb 07 14:32:47 2005
I've set my paths correctly, I'm running v6.62 of MPLAB.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 07-02-2005, 14:55
Re: Error: Unable to locate 'stdio.h'
Do you have the newest version of the compiler (2.4) installed?
Unread 07-02-2005, 15:00
phrontist's Avatar
Proto-Engineer
Ah, that could be it. I'll check back after trying that.
UPDATE: How do I get it?
Unread 09-02-2005, 19:10
GAT-X105 STRIKE's Avatar
GAT-X105 STRIKE GAT-X105 STRIKE is offline
GAT-X105 STRIKE can only hope to improve
It should be on the FIRST website somewhere, or that MPLAB website, but the FTP is down now...
Unread 09-02-2005, 19:59
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
I don't think stdio.h was included with the 2.2 compiler, so that might be it.
There are other possibilities too, though: Make sure you have C:\MCC18\h listed in the Include Path $(INCDIR) on the "General" tab of the Build Options dialog. (Modify as need if you installed the compiler other than in c:\mcc18.) Also make sure your code has #include <stdio.h>, and not #include "stdio.h". Otherwise the preprocessor will only look for the file in the current directory, and not in $(INCDIR).
stdio.h complilation error reilly Programming 4 01-02-2005 20:49
PLEASE help me locate pictures from Buckeye ... Stu Bloom Regional Competitions 17 10-05-2004 09:20
Where can we locate another Double Solenoid? David Hoff Pneumatics 1 03-02-2004 00:13
