Go to Post So, FIRST is turning into the For the Inspiration of Science and Trains? That makes sense... Not a whole lot of re-branding will be needed.... - dqmot17 [more]
Unread 05-02-2005, 18:04
Fishdude404's Avatar
Fishdude404 Fishdude404 is offline
The fish king!! MUHAHAHAHAHAHAHAHAH
AKA: Andy Hsiao
None #1510 (Westview Robotics)
Team Role: Scout
Fishdude404 is an unknown quantity at this point
Send a message via AIM to Fishdude404 Send a message via MSN to Fishdude404 Send a message via Yahoo to Fishdude404
R/C helicopters
i was wondering if you could use gyro's from model helicopters. I've done research on them before, but i'm not sure if you can use them for robots.
----My Setup----
-Tippmann A-5
-E-grip
-J&J 14" Ceramic Barrel
- Two wrongs don't make a right, but three lefts do
- If I agreed with you, we'd both be wrong
- Happiness is like peeing in your pants. Everyone can see it, but only you can feel it's warmth.
Unread 05-02-2005, 18:12
Der Sichelmann's Avatar
Der Sichelmann Der Sichelmann is offline
Professional Team Member
#0358 (Eagles)
Team Role: Student
Der Sichelmann is an unknown quantity at this point
Re: R/C helicopters
They have to fit within the cost rules. But typically helicopter drive the PWM directly to the motor and that is not legal.
Unread 07-02-2005, 10:49
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Re: R/C helicopters
Run them through the flow chart for part legality.
Unless you can get them from one of the approved suppliers of electrical parts, i doubt if you can use them, but then again i haven't slept in 2 days, so i could be wrong.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 07-02-2005, 14:07
Re: R/C helicopters
You all need to check the Q&A, the answer was given that the type specified and shipped in the KOP are the servoes you need to use.
Unread 07-02-2005, 15:38
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: R/C helicopters
You're probably referring to R38:
<R38> Specific items allowed include:
• Additional HITEC HS-322S servos
• Additional Victor 884 Speed Controllers and Spike Relays, as needed.
• Additional solenoid valves, air cylinders, and connecting fittings
Unread 07-02-2005, 20:40
Re: R/C helicopters
Fishdude404 was asking about gyros, not servos.
Assuming it falls under the cost limit, I don't see anything in the rules (or the flowchart) that would, um, rule out a helicopter gyro. Passive sensors of pretty much any sort seem to be permitted.
Unread 10-02-2005, 19:14
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Re: R/C helicopters
About gyros driving PWm applications:
Typically speaking, you are right. In a model, a gyro hooks between the controller and the servo that requires the mixing. In the robot, however, you can use the PWM that would normally drive the servo to input into the robot controller (you may need to feed a 50% duty cycle into the gyro to simulate a neutral stick. Because gyros disengage when the stick moves from center, you may have to make it seem like a center stick all the time.)
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
World's Fastest R/C Car, anyone? Billfred General Forum 75 05-08-2005 12:56
Header rows on the R/C Justin Stiltner Control System 7 04-02-2004 23:27
How to connect the R/C receiver?! Tim Skloss Robotics Education and Curriculum 7 10-12-2003 16:34
EDU R/C Based Robot Venkatesh Technical Discussion 2 02-12-2003 15:20
R/C Control types Andy Brockway Programming 43 24-11-2003 17:07
