| Hey Slick, I'd slide on thin ice for you. |
How to control piston?
I've got a rookie team question for all of you, sorry if it has been asked before, but I've done a ton of searching with no luck:
We are using the pneumatic piston/cylinder, and we are unsure how to connect the pneumatic circuit to the controller (which we need to know how/what to program). How do we connect them and control the pressure to make the piston/cylinder fire and retract? Thanks in advance. |
Re: How to control piston?
relayX_fwd = pY_sw_trig; relayX_rev = pY_sw_top; //In this, X represents the relay output number and Y is the joystick port. |
| 2005 RadioShack® Innovation in Control Award! | dez250 | General Forum | 10 | 10-03-2005 21:29 |
| What do you wish you knew about the new control system? | Joe Ross | Control System | 2 | 09-01-2004 21:47 |
| Need a FIRST Robotics control system | kershawrobotics | General Forum | 3 | 07-07-2003 09:49 |
| how do i control a piston with a joystick | Ryan Foley | Programming | 2 | 27-05-2003 17:13 |
| more control options | smokescreen | Technical Discussion | 17 | 05-03-2002 15:41 |
