Go to Post This is what happens when a couple of whackos get an idea at 2 am. - Rich Kressly [more]
Unread 07-02-2005, 17:20
Goaliexam Goaliexam is offline
AKA: Max
FRC #1656 (Haverford Robotics)
Goaliexam is a jewel in the roughGoaliexam is a jewel in the roughGoaliexam is a jewel in the rough
Send a message via AIM to Goaliexam Send a message via MSN to Goaliexam
Re: How to control piston?
Originally Posted by Tom Bottiglieri
You can connect the piston to a double solenoid. Then connect one of the red wires coming from the solenoid to the M+ on a spike relay. Attach the other red wire to the M-. Attach both black wires to your ground hub on the circuit breaker. Then in code, you can write this.
relayX_fwd = pY_sw_trig;
  relayX_rev = pY_sw_top;
//In this, X represents the relay output number and Y is the joystick port.
Thanks, I'll give that a try.
2005 RadioShack® Innovation in Control Award! dez250 General Forum 10 10-03-2005 21:29
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
how do i control a piston with a joystick Ryan Foley Programming 2 27-05-2003 17:13
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
