Go to Post I have never gone to a FIRST Robotics competition and not had fun. - mathking [more]
Unread 07-02-2005, 08:37
krhs_programmer's Avatar
krhs_programmer krhs_programmer is offline
Programmer, Engineer, exDriver
#1247 (R.O.K.S.)
krhs_programmer is an unknown quantity at this point
Exclamation Dead battery!
This past saturday we were running our robot around at our facillity and something very odd happened. We have a big open carpetted room with a cubicle w/a metal strip along the bottom. Our robot generates a considerable amount of statc electricity when we drive it because of the carpet and the wheels and when you hit themetal strip on the cubicle it discharges. Also when you hit something hard enough w/the robot the circuit breaker clicks off. So when we were driving it we hit the cubicle and and the robot discharged and turned off. OK cool what ever. So we go to turn it on and it won't fire up, so we shut it off again. We went to disconnect the battery and when we grabed the connector we drew back in pain because it was burning hot! We let it cool and disconnected it and put the volt meter on it and it read .25 volts. The battery went from fully charged at 13.4 volt to .25. Please explain this!
Unread 07-02-2005, 09:07
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Dead battery!
Are you sure you were measuring it correctly? It seems impossible that it rapidly discharged like this. You would have to have noticed the robot slowing down and becoming weaker. It probably would have stopped running entirely before it got anywhere near .25V.
The discharge may have been caused by some sort of connection of the battery to the frame and consequently to this metal strip. A short like that may also explain the hot connector (caused by a large amount of current flowing through it caused by the short).
Team 1257
Unread 07-02-2005, 09:43
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Dead battery!
Hot battery, rapid discharge, throwing the breaker.
These are all the telltale signs of a short circuit my friend.
Do you have any wires which might be coming into contact with your frame? Or would you happen to be using your frame as a ground return?
-SlimBoJones...
Unread 07-02-2005, 10:46
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Re: Dead battery!
I agree with Slimbo,
Use a continuity tester and check the frame and make sure it is not grounded. Also check to make sure that all the connections on the batter and in the electrical system are tight and in good condition, if there is poor contact there is increased resistance which will cause all sorts of problems.
It is my understanding that with the current breakers it is supposed to be very dificult to trip them simply by hitting something, although with the old one it was very easy. Unless you are drawing way more current then you should be, in which case it would be easier to trip the breaker.
So my advice would be to recheck ALL the connections in your electrical system, check the connectors for any signs of wear and tear on the battery, check to make sure nothing is grounded, double check the voltage on the battery, and just make sure you didn't overlook anything.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 07-02-2005, 10:53
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Re: Dead battery!
Check your drivetrain too. If you are careening along at a pretty good clip then you hit a wall or whatever it could be that something in your drivetrain is a little bit loose and it catches and binds, when those CIMS go from full speed to nothing with power still applied they probably draw a tremendous amount of current.
Just a thought. It doesnt really explain the battery thing, but what I can say is that what you are having happen should not happen. I know, im so helpful.
Unread 07-02-2005, 11:17
Rocketboy's Avatar
Rocketboy Rocketboy is offline
Programmer at work, Pilot by heart
AKA: Daniel Schoessler
FRC #1317 (Digital Fusion)
Rocketboy will become famous soon enough
Send a message via ICQ to Rocketboy Send a message via AIM to Rocketboy
Re: Dead battery!
I don't think the CIMS alone could draw THAT much though. Last saturday we we're running our bot' around the warehouse and we had a draw of about 3v when at full speed, and when we reversed from full to back full there was an increase of .5 or so.
BUT, I as a programmer have implemented a "rampPWMs" program which "ramps" the output to the motor. If your team's programmers havent written a program they should. It should help a little bit. If you want to know how to do that I'll show you what I did.
-- Unofficial Google Advocate --
I soloed my
"Skyhawk" before I even soloed my car!
Unread 07-02-2005, 13:57
Re: Dead battery!
There is something missing from this picture...The hot connector and dead battery would indicate a dead short somewhere after the main breaker (since that tripped) but you have said nothing about any of the other breakers tripping. So this leaves us with a dilemma, what could be wrong?
1. The breaker panel itself shorted. (doubtful without some other visible sign. i.e. smoke and flame.)
2. Wiring between the main circuit breaker and breaker panel shorted. (most likely cause, might be a main breaker that is not secure and moves against the frame.)
3. Not using the breaker panel or not using the specified 40, 30 and 20 amp breakers in series with the motor types used for this season. (Not likely, teams don't bypass safety features like a breaker panel and specified breakers.)
You have not mentioned that you tried a new battery and all was OK so I am assuming that you are still troubleshooting before connecting a known good battery. I would disturb as little as possible, remove all the breakers from the panel, and measure the resistance at the robot end of the battery connector. It should be infinite regardless of whether the main breaker is closed or open. If it reads less than a few thousand ohms with the main breaker closed, but not open, your problem is after the breaker. Disconnect the breaker panel and test again, if the resistance reading goes high, than suspect the breaker panel.
Unread 07-02-2005, 16:04
#1247 (R.O.K.S.)
Re: Dead battery!
Sorry about the lack of info. i didn't have much time before. But the neg. (-) terminal on the battery was exposed and the battery was held in the robot by the latex tubing and it could slide. Today when i came in the battery had a charge put back on it and when i put the volt meter on it i watched the voltage rapidly drop. Also we put a good battery in saturday and it was fine. And it would be much appreciated if you could show me how to program that rampPWM you were talking about.
Unread 07-02-2005, 16:41
Rocketboy's Avatar
Re: Dead battery!
I'll have to get a copy of it from my comp at the build site, and once I do I'll show it here.
I soloed my
Unread 07-02-2005, 17:22
occra 23.
AKA: ryo
None #1481
Re: Dead battery!
by the way if you're wires are that burning hot id advise you to disconnetct first anyways because there just MIGHT be the chance it wont cool down (and keep getting hotter till sumthing blows or melts. at worst (with rc car experiences) you might even need to cut the wire. but never cut two wires at once.
Unread 07-02-2005, 19:23
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Re: Dead battery!
This is to be expected. Bringing the battery below 11 volts can start to cause perminant damage, and if you really did manage to get your battery down to 0.25V, the thing is toast.
Zan Hecht
Unread 07-02-2005, 19:27
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Re: Dead battery!
Quick question regarding one of the above posts:
Were you able to charge the battery back up? If not, then you may have an internal short (SLAs depend on metal plates with acid between them. If the plates short, then you have a problem, but that doesn't explain the hot breaker wires). In any case, it sounds like you had a HUGE amount of current go somewhere really fast. That's downright dangerous. One thing is niggling, though: why is it that the wires did not actually melt? It seems to me that even a somewhat discharged battery, if it were to short using the breaker wires, would fry them in a heartbeat. If the voltage levels did drop that much, then it seems semi-logical that there would be scorch marks along the path the power took to whatever circuit it seems to have made. Make sure this gets solved before competiton!
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 08-02-2005, 07:32
Re: Dead battery!
I am guessing that when the robot took a hit, the negative terminal made contact with the robot frame. I expect that an inspection (with VOM) will show that the positive lead is in contact with the frame, probably at the output of the main circuit breaker. When the battery slid against the frame, a circuit was formed through the frame, battery, main breaker and associated wiring. This kind of abuse can result in the internal plates of the battery warping and the result is there is an internal short. When the battery was put on the charger, it may have taken longer than normal to show full charge (or it never achieved full charge) and would have been much warmer than other batteries while charging. You should also check that the battery connector has not so badly deformed from the original heat that the contacts are now touching. If you are sure all of the wiring on the battery is correct and there are no sneak paths for the current, then the battery is a candidate for recycling.
Check the wiring on the robot for contact with the frame, correct what you find and always insulate both battery terminals at all times.
Unread 08-02-2005, 15:15
#1247 (R.O.K.S.)
Re: Dead battery!
Battery terminals were insuled with heat shrink over them but the person who did it didn't do a very ggod job and it came off and thats how it could complete the curcuit. The possitive(+) terminal was the hottest of the 2 on the battery and the same for the one coming off the curcuit breaker. Where as the negative(-) was as cool as a bone. The wire was hot but not quite hot enough to melt the wires plastic coating. And yes the curcuit breaker will pop open if you hit it hard enough, well atleasr ours does which won't be very good in the competition if we get hit. And as for charging it, i don't know how they got it to charge. Because when we put it on saturday and stuck the volt meter to it the voltage dropped. But when it was charged and the volt meter was put on it, it wold rapidly drop.
Unread 09-02-2005, 07:27
Re: Dead battery!
Well it sounds like this battery is going to the recycler.
The circuit breaker should not open when hit. If yours does, I would recommend replacement. We had a defective breaker this season that would open with any pressure on the red button. Opening the device showed that manufacturing had misaligned the internal parts. There are no parts that can trip open this design as there had been in the breakers from several years ago. If yours trips open with shock it is defective.
Why MUST the 7.2v battery be attached to operate servos on the RC? Mike Rush Control System 17 06-02-2004 18:57
Jump Start RC w/o Exide 12v battery Mark McLeod Control System 3 12-01-2004 12:42
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
