Go to Post Searching is your friend - try it. - Katie Reynolds [more]
Unread 07-02-2005, 19:32
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Self-fabricated electrical connections
If I am interpreting the rule correctly, no. The rule is, and I quote
<R40> Additional electronic components for use on the robot must be either COTS items, or assembled from COTS items. Additional electronic components include any object that conducts electricity other than IFI relays and speed controllers, wires, connectors and solder.
Obviously your connector conducts electricity, so it falls under this rule. If you use a #6 gage connector from the hardware store, you are good. But if you make a connector from scratch, it doesn't constitute a "Commercial, Off-the-shelf" component (at least I don't think so). Your best bet would be to run over to the hardware store and spend 15 cents on a crimp-on connector.
Aren't signatures a bit outdated?
Easy to swap out electrical controls? cbolin Electrical 13 25-12-2004 11:37
Electrical Tips for Rookies Anne Shade Technical Discussion 15 03-12-2004 12:08
Looking for team 217 Electrical mikey1126 Electrical 15 21-04-2004 22:10
Lots of Electrical Questions Allison K Electrical 18 18-02-2004 11:49
Electrical connections and multimotor mechanisms kmcclary Off-Season Events 2 11-10-2001 14:15
