Go to Post Ya know...sometimes, design specs get changed at the last second. Or the market changes while you weren't watching. It Happens. - DonRotolo [more]
Unread 31-01-2005, 16:37
PSeid-991 PSeid-991 is offline
PSeid-991 is an unknown quantity at this point
Inventor Help
Hey,
I'm trying to learn how to use Inventor, I did most of the tutorials, but I can't figure out how to cut the rail for the robot that i found on the Internet, can anyone help me? I don't know it I'm using the wrong file or just don't know what tool to use.
Peter
Unread 31-01-2005, 17:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Inventor Help
If the rail is an feature that is extruded along its length, you can right click that extruded feature in the browser bar and select "edit feature" to change the length. Or. You can make a new sketch on one end of this rail, and then "extrude cut" back however far you want. Or you could sketch on the side of it however much you want to take out, and "extrude cut" that away.
Unread 31-01-2005, 21:59
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
Re: Inventor Help
Or, if you are trying to cut on an angle, make a work plane (defined by three points usually) that is at the right angle and use 'Split'. Select the work plane and then select that you want to remove a side. Select all of the many faces that are involved and click OK. If the wrong side is removed, edit the feature and click the button that has 2 arrows going in opposite directions (this icon reverses the direction of a selection in almost anything).
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 01-02-2005, 23:45
Re: Inventor Help
Hey,
I haven't been ably to try it yet, but it seems to make sense.
Thanks,
Peter
Unread 02-02-2005, 16:47
Re: Inventor Help
Hey,
I tried to use the extrude tool, but is there was an error message that said, "No Unconsumed Visible Sketches." What can i do to extrude, or was the not what u were talking about. Also when i try to make a work axis, it puts up a message that says, "Work Plane3: Could not build this Plane by three points." Maybe the problem is that I'm not using the right kind of file, or I'm completely confused. Any help you can give would be appreciated.
Thanks,
Peter
Unread 02-02-2005, 17:07
Re: Inventor Help
Either make a new sketch of the area you want to "cut away" or you can (in the browser bar) right click on a particular sketch and chose "share sketch" Then you should not get the no unconsumed sketches error.
But even before all that, is the current part an extruded feature? If so, have you tried just editing the length of that extrusion?
Unread 03-02-2005, 16:30
Re: Inventor Help
Hey,
I finally figured out what you were trying to say, but when i try to use the general dimension tool, it says, "Cannot constrain or dimension reference or fixed geometry" what am i doing wrong?
Thanks,
Peter
Unread 03-02-2005, 18:52
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
Re: Inventor Help
I'm assuming you put a new sketch on a face. If you did it on the end, celebrate, because all you have to do is go to part features, click on extrude, click on the picture that indicates cutting away (it's the middle one), enter the distance you want to extrude, and you're done.
If you are doing it from the side, it's a little more complex but it isn't all that bad. On your new sketch, make a line that is coincident (touches) the top and bottom of what you want to extrude. Make sure the line is paralell to the end of the piece (or perpendicular to the lines it touches, it's the same thing). Then click on general dimension, and click on your new line (the green one) and the end of the piece that you want to extrude. On the dimension, enter the distance that you want to cut the piece back, and go to extrude. It will ask you to click a profile, so click what you want to extrude away. Click on the thing to extrude the piece away, and where the thing that says distance is, click on the arrow to the right of it and change it to all.
Good luck and HTH,
Daniel
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 03-02-2005, 19:42
jdiwnab's Avatar
AKA: Bryan Hartley
FRC #0617
Re: Inventor Help
Inventor is saying that you can't dimention some part that is already made. You are probably making a sketch on a face of an already extruded part. That face's geometry is now part of the sketch, but you can't change the dimentions of it in you current sketch. If the part is the wrong size, you need to go to it's sketch that you made it from to change it.
One thing you have to remember is that Inventor is what they call Parametric Modeling. This is a fancy term to say that every dimention is related to the others. If you make an extrution and then make another extrution the same shape as the first, then edit the first one, the second one will change. That isn't the only example, but is easy to understand. Also, if you want an object to be always square, no mater what size, you can tell one dimention on a rectangle to be whatever the other one is.
When you dimention something in a sketch, you are really telling it the size it needs to be. AutoCAD tells you how long something is. Inventor tells you how long something is and wants you to change it. To do the same thing in AutoCAD, you have to remake a part.
The power come from, aparently, a huge database of dimentions and other things you have made. Our chassis model is in an assembly and has about 600 dimentions, including constraints, which are dimentions of a different type.
// random()
Unread 07-02-2005, 22:18
Re: Inventor Help
Hey,
Does anyone know where i can get 35 gear chain for Inventor, or are we not expected to use chain? If we are expected to use how would we go about using the placing the chain on the gears. Also does anyone know where i can get all of the components for the 2005 first 8 inch wheel?
Thanks,
Peter
Unread 07-02-2005, 22:20
Re: Inventor Help
CORRECTION: When i said gears in the last post, i meant sprokets
Peter
Unread 08-02-2005, 12:16
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Re: Inventor Help
Originally Posted by PSeid-991
Hey,
Thanks,
Peter
The Big Two of Inventor download sites:
http://www.firstcadlibrary.com/
http://www.cbliss.com/inventor/index.htm
The wheel is in the IFI kit of parts files:
http://www.ifirobotics.com/kitbot.shtml
Search is your friend and it likes to be used! This info has been given out at least two times already this year.
Pete Kieselbach
Unread 09-02-2005, 17:43
Dark Templar Dark Templar is offline
Dark Templar has a little shameless behaviour in the past
Question Re: Inventor Help
Exactly how would i make a pyramid shape? ...half sphere shape?
I've been trying to make one for... uh... a while. It's beginning to frustrate me! I have been looking through all of the options and tutorials... (or so it seems) ... so, any help would be greatly appreciated.
-FOR AIUR!!!
P.S. how do i get my signature picture to actually show up!?!?!
POWER OVERWHELMING!!!
Unread 09-02-2005, 17:48
jdiwnab's Avatar
AKA: Bryan Hartley
FRC #0617
Re: Inventor Help
If you know all of the angles involved and the lengths of the sides, you can do it. Make a sketch of a triangle (I'm assuming that you mean the Tetras). Make sure the angles and lengths are right using constraints. Finish the sketch and extrude to a good heigth. then use taper to narrow it down. Enter the angle and you should be good to go. This is, howerever, a long path and there might be a better one.
// random()
Unread 09-02-2005, 17:55
Re: Inventor Help
this one is for all those who have the skillz to make the team logos!
- i came up with this one not too long ago, i decided to make our team logo ON inventor! could be tricky, but the end result wouls be really cool looking!-
and what about the getting the pictures on the signature???
