Go to Post Basically: engineering is fun. - Mike [more]
Unread 04-02-2005, 22:01
Phil Roth Phil Roth is offline
#0011 (BASF)
Phil Roth is an unknown quantity at this point
Send a message via AIM to Phil Roth Send a message via Yahoo to Phil Roth
Camera lens not straight?
Has anyone noticed that the camera doesn't point exactly at the target even though the pan.servo is reading 128.???
It's not any adjustment in our mounting either. The camera is responsible for centering the centroid in the field of view regardless of how the servo is mounted. The only way it can point straight is if we shim the lens about 15 degrees.
Unread 07-02-2005, 23:10
#0011 (BASF)
Re: Camera lens not straight?
We found that the pan.servo was positioned to 135 not 128 when the centroid was @ 80 which places it exactly in the center of the field.The packet:
T 80 120 60 100 100 140 32 158 135 131
clearly shows the mid mass of X is @ 80 which is 1/2 of the width of 159. Changed both the camera moduleand UbiCom board.... same problem..
WHAT's UP WITH THAT ????
Unread 08-02-2005, 15:52
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Not sure what you mean here.. our camera won't always look like its pointing at something, but it will still have a lock on it and track it sucessfully.. Is the red light steady on the front of the camera?
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Unresponsive camera neilsonster Programming 9 17-02-2005 08:51
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
Game Field Camera Calibration Matthew_H Regional Competitions 2 15-01-2005 23:09
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
