Go to Post Meanwhile I'm over here with with my completely see-through poly-carbonate blocker prototype laughing. - JohnFogarty [more]
Unread 08-02-2005, 16:04
sgsdragons's Avatar
sgsdragons sgsdragons is offline
Team1595
AKA: Josh Lambeth
FRC #1595 (The Dragons)
Team Role: Driver
sgsdragons will become famous soon enoughsgsdragons will become famous soon enough
pic: Team 1595 Prototype!!! L@@K
Ok, here is our prototype robot. We have had it finished for about 3 days now and we are now tweaking, testing, and practicing while our final parts are being made. The first pic is the robot collapsed. The second is with it extended and gives you an idea of how tall it is. Hope you enjoy. Please post feed back.
Folded Up:
Extended:
SGS Dragons
Unread 08-02-2005, 16:09
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
Re: pic: Team 1595 Prototype!!! L@@K
that looks really good. I like the arm.
Do you plan on cleaning up the wiring and tubing? They can get caught in anything and that could be very bad.
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 08-02-2005, 16:15
sgsdragons's Avatar
Team1595
AKA: Josh Lambeth
Team Role: Driver
Yes, we are doing that. Today I will be making the main electronics board so that it will look better and not get caught. We are also planning on changing our drive system to 6 wheel drive instead of the two wheel drive we have now. I will post more pictures when we get them going.
SGS Dragons
Unread 08-02-2005, 16:24
pakrat pakrat is offline
Rich Ross
no team (The Rat Pack)
pakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nice
Send a message via AIM to pakrat
FIRST chassis and transmissions, right?
Unread 08-02-2005, 16:44
Jaine Perotti Jaine Perotti is offline
...misses her old team.
AKA: BurningQuestion
FRC #0716 (The Who'sCTEKS)
Jaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond repute
Send a message via AIM to Jaine Perotti Send a message via MSN to Jaine Perotti Send a message via Yahoo to Jaine Perotti
Looks good. I have a couple of questions...
Does that tetra manipulator (on the end of the arm) work by sliding the two pieces of PVC in and out to pick up tetras? Are you planning on being able to drive around with the arm folded in while holding a tetra at the same time? I think that is a cool idea.
Also, how long of a stroke does the big cylinder have? Does it use up alot of air? Will you have to be constantly starting up your air compressor during the match, or are you planning on using that cylinder relatively few times? My only concern is that using a large cylinder like that might require the air compressor to run alot, and therefore drain your battery faster.
And I am glad that you are going to use 6 wheel drive... casters (I think thats what I see in the picture) can make your robot easier to be pushed around. Also, are you planning on using those KOP wheels? Personally, I think that they might not have enough traction for holding your ground while trying to cap. When you do your 6 wheel drive, are you going to lower your center wheel a little bit for better turning?
How much does your chassis weigh? How much does your arm weigh? Are you concerned about center of gravity issues at all? Are you afraid of having too much weight in the front? You could try to counterbalance the weight of the arm by moving the heavier components of your robot to the back.
Are you planning on adding any shielding? The way it looks right now, some of your electrical components are vulnerable, such as those spikes on the bracing. The robot controller on the back looks like it might take a whack too. Shielding would be very easy to add... all you need is some lexan, a drill, and some zipties!
What is the wall thickness of the angle aluminum used for the first section of your arm (the "mast")? I can't quite tell. If it is as thin as/thinner than 1/8 inch, you might end up with some interesting dents or bends by the end of competition season. Be aware of the loads that the arm will have to bear when it is counteracting other robots, as well as lifting the game pieces.
Oh, and what is the big muffin fan on the side for? And where are you putting your battery (unless for some reason I missed seeing it)?
Overall, nice design... looks great. Thank you for bearing with my questions...I have a tendency to ask alot!
-- Jaine
Florida Institute of Technology
Ocean Engineering, '12
Unread 08-02-2005, 17:25
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
hmm,
my team used that honkin' 24" stoke cylinder last year to make the pullup....if i was you, i would definatly not wanna keep reaching up/down as your battery will be dead faster than vanilla ice's career. BUT i do see you have a cooling system for your compressor, that right there is gonna be the difference between how well your bot will constantly be raising and lowering that arm. i like it.
looks good guys, seems pretty solid for a rookie team. good luck
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 08-02-2005, 20:26
Collmandoman Collmandoman is offline
Post-A-Holic
Collmandoman has a spectacular aura aboutCollmandoman has a spectacular aura aboutCollmandoman has a spectacular aura about
1595, you all are doing a great job! Keep up the great work@!!!!
Unread 08-02-2005, 21:01
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
looking good. Our deisgn is almost identicle(sp) except we opted for geared down motors, they gave us a greater reach, posisitonalublity, and are easier to get to any one point than stopping pnuematics
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
Unread 08-02-2005, 21:32
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Your robot looks very awesome. Looks a lot like something someone was telling me about though...I was wondering...would you happen to know anyone by the CD username JoshJ?
Unread 09-02-2005, 13:02
sgsdragons's Avatar
Team1595
AKA: Josh Lambeth
Team Role: Driver
Hey, Thanks for all your support on everything. And for all the questions, we are able to run our compressor for almost the whole match and still be fine. We don't use as much battery power as you would if you were starting and stopping all the time. Another thing is that we added some support and helper pistons to make it easier for us to lift. I will get some pics up later today of it. And we HAVE decided to go with 6 wheel drive as it will help use greatly for driving. As for the center of gravity, we have it pretty well nailed. We haven't had any problems with tipping over and we can have our arm extended all the way w/a tetra on the end and not have any problems with tipping. It's really stable. We are also going to be replacing the back A from with something a little more stable. The parts are all being made as we speak.
Keep the comments coming, and if you have any ideas or concerns, please let us know as we are just starting and are a rookie team. THanks
SGS Dragons
2005 Pacific Northwest Regional Winners
2005 Pacific Northwest Regional Judges Award Recipiants
Our Team would like to thank both Team 492 and Team 604 for helping our team win the Pacific Northwest Regional.
2006 Season...
Reginal Event: Las Vegas!!!
Nationals: Atlanta!!!
Unread 09-02-2005, 13:04
sgsdragons's Avatar
Team1595
AKA: Josh Lambeth
Team Role: Driver
"Your robot looks very awesome. Looks a lot like something someone was telling me about though...I was wondering...would you happen to know anyone by the CD username JoshJ?"
And by the way, no I don't know this person.
SGS Dragons
2006 Season...
Unread 09-02-2005, 13:11
Zanella BR's Avatar
Zanella BR Zanella BR is offline
Brazillian FIRST Team Member
AKA: Leandro Zanella S. Campos
None #1382 (Tribotec)
Zanella BR will become famous soon enoughZanella BR will become famous soon enough
Send a message via ICQ to Zanella BR Send a message via AIM to Zanella BR Send a message via MSN to Zanella BR
Photo 1: I hope your final robot will have a better wiring...
Photo 2: Where are the security glasses?!
For both photos: congratulations, really nice job!
The Lightning Hunter
#1382
2004 - NJ Regional -3rd place (Rookie year)
2005 - NJ General Motors Industrial Design Award
2005 - NJ Website Excellence Award
2005 - NJ Safety Award
[<o>]
Brazil's 3rd Team
Unread 09-02-2005, 13:51
Post-A-Holic
how much does your arm weigh? =)
Unread 09-02-2005, 16:26
sgsdragons's Avatar
Team1595
AKA: Josh Lambeth
Team Role: Driver
Ok, Here is a picture of our helper pistons. They are basicly the same thing that you use to help open the trunk of your car. We have one on each side of the wrist part of our arm and then a large on on the main arm (Not pictured). Here you go:
SGS Dragons
2006 Season...
Unread 09-02-2005, 22:47
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Nice job so far guys. Just a couple questions, how many tetras can you stack on each goal, and can you cap the center goal?
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
pic: team 1595 Wiring Job sgsdragons Robot Showcase 9 08-02-2005 13:09
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
