Go to Post You're on a team, weren't you taught Gracious Professionalism? It doesn't only apply to competitions, it applies to the real world. - Zac Schofield [more]
Unread 08-02-2005, 16:51
Chris Bright's Avatar
Chris Bright Chris Bright is offline
#1023 (Bedford Express)
Team Role: Webmaster
Chris Bright will become famous soon enough
Send a message via AIM to Chris Bright
ADXRS300EB gyro help
I am wondering if any one can confirm the pins for the evaluation board is pin 1 = power, pin 2 = rate out and pin 8 = ground. I tried using the default code and only change was the gyro selection. I am getting no gyro rate in the terminal.
2003 - National Rookie All-stars
2003 - Great Lake Rookie All -stars
Unread 08-02-2005, 16:54
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Re: ADXRS300EB gyro help
Kevin's default gyro code is set to analog 1 - make sure your gyro is connected to analog 1 unless you have changed it in the code.
Unread 08-02-2005, 17:02
It is. i get a rate sometimes but never higher than five
Unread 08-02-2005, 17:33
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Did you connect AVCC (pin 1) to PDD (pin 13)?
-Kevin
Kevin Watson
http://kevin.org
Unread 08-02-2005, 17:59
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
Thats a negative. didn;t know you had to do that, thanks for the info!
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Gyro Troubles SteveO Programming 13 30-01-2005 16:46
ADXRS300EB Rate Gyro rmeenaks Electrical 18 05-04-2004 22:37
ADXRS300EB Rate Gyro rmeenaks Technical Discussion 0 31-03-2004 16:48
