Go to Post It's important to know that it isn't always best to have biggest machine out there. - Quatitos [more]
Unread 08-02-2005, 22:27
chantilly_team chantilly_team is offline
chantilly_team is an unknown quantity at this point
Can you make your own joystick?
Hey Guy,
We were wondering if we can make our own custom joystick without using the ones provided. We were making it out of potentiometers. So can you convert potentiometers into the joystick ports?
Thanking you in anticipation.
team 612.
Unread 08-02-2005, 23:03
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: Can you make your own joystick?
Of course.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 08-02-2005, 23:09
MOEmaniac's Avatar
MOEmaniac MOEmaniac is offline
The Crazy One
AKA: Steve
FRC #0365 (MOE)
MOEmaniac has a spectacular aura aboutMOEmaniac has a spectacular aura about
Send a message via AIM to MOEmaniac Send a message via Yahoo to MOEmaniac
Yes you can. I on the other hand don't know how but I do know that team 25 last year had a joystick that was a replica of their arm and it used pots.
When logic fails, force prevails!
2005 Record
Pittsburgh Regional: #1 seeded, Finalist - Thanks teams 808 and 869, Entrepreneurship Award, Sportsmanship Award, Website Award
Philly Regional: #2 seeded, Champions - Thanks teams 56 and 316, WFA Lou Rosanio, Chairmans Award
Nationals: Still to come
2004 Record
New Jersey Regional: Quarterfinalists - Thanks teams 25 and 103, Judges Award
Philly Regional: Quarterfinalists - Thanks teams 1370 and 1143, Imagery Award, Website Award, WFA Joe Perrito
Nationals: Galileo Finalists - Thanks teams 177 and 27, National Imagery Award
Unread 08-02-2005, 23:11
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
Originally Posted by chantilly_team
Hey Guy,
team 612.
aslong as it does not require an outside powersource, then yes it is legal
Originally Posted by section 5 pg19
<R69> All equipment connected to the Joystick Ports of the Operator Interface must be powered solely through the power available through the port. External power sources of any type are not permitted on any equipment connected to the Joystick Ports. Portable computing devices may not be connected to Joystick input ports on the Operator Interface.
you will also need to know the pinouts for the joystick ports, read the OI manual here: http://www.ifirobotics.com/docs/oi-r...de-1-25-05.pdf , the pinouts are located on page 7,8,9,10
on page 25 of the Guidelines Tips and Good Practices of section 5 of the manual (found here: http://www2.usfirst.org/2005comp/Man...idelines_C.pdf ) you will see the pinouts for Potentiometers
hope that helps
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 08-02-2005, 23:39
Ryan Albright's Avatar
Ryan Albright Ryan Albright is offline
Just Browsing
AKA: ryan albright
Ryan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond repute
Send a message via ICQ to Ryan Albright Send a message via AIM to Ryan Albright Send a message via MSN to Ryan Albright Send a message via Yahoo to Ryan Albright
My old team (710) made a custom joystick last year. It was a downsize of our arm. It contained two potentiometers. As long as you stay in the rules of what Big mike posted you will be good.
Good luck
Alumni of 710 2001-2004
Mentor 1083 2005
2005 UCF regional lead safety advisor
2005 Championship Safety advisor
Unread 09-02-2005, 16:33
Good luck
Thats exactly what we want to do, by using two or three potentiometers in our replica of our arm. But we dont how exactly to convert the potentiometer into joysticks. Or how to connect them into the joystick ports on the Operator Interface. We would really appreciate if you tell us how to do that.
Thanks,
Team 612.
Unread 09-02-2005, 16:42
Billfred's Avatar
Billfred Billfred is offline
To connect pots (100 kOhm) to your OI, you'll need a DB15 gameport connector. You can cannibalize a bad joystick for one, get them from whereever you got the connector for your competition port dongle (they're the same connector) or find a rather obscure electronics store that still sells them. (I found one just by asking around at the big electronics stores, and someone mentioned it. Cable and Connections on Leaphart Road in (West?) Columbia SC, if you're interested.) Make sure you also get a backshell, to keep from accidentally grounding pins you didn't want grounded.
From there, follow the wiring diagram in the OI manual on www.innovationfirst.com and check it before you plug things up.
Hope this helps!
Unread 09-02-2005, 21:12
Solder cups on the back are good too. We pick ours up from the local electronics junk superstore, Halted Specialties Company (or something like that : http://www.halted.com)
Help with Joystick Axes and Sensitivity bglass Programming 6 06-02-2005 14:01
need help w/ joystick code willie837 Programming 6 02-02-2005 23:17
Error - symbol 'e' has multiple definitions. HELLPPPPP BookerT Programming 2 24-01-2005 21:50
Tri-axis Analog Joystick KVermilion Control System 5 19-01-2005 00:24
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
