Go to Post Obviously, really large issues need to be addressed, and if you feel there is a huge problem, by all means, go ahead, if you can be polite, productive, and graciously professional, address it. - Amanda Aldridge [more]
Unread 08-02-2005, 23:35
Zippiot Zippiot is offline
punching bag
Zippiot can only hope to improve
Send a message via AIM to Zippiot
van door power question
will 2 van door motors (from previous years, each attached to its own motor for tank drive) be able to pull itself with a human on it and a Cart with the bot? any wheels will work, but it must be able to travel at least 3 feet/sec. will i have to gear it or are they powerful enough?
Unread 08-02-2005, 23:46
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
Re: van door power question
We have made a cart using the van door motors in the past and geared them down and they had much more power then we really needed so I think you may be able to drive it with out gearing them.
Unread 09-02-2005, 23:19
punching bag
with a 9 inch diameter tire a direct drive from the van door motors at 70 rpm should be going about 2.7 ft/sec or 1.8 mph, just below walking but right about how fast a robot on the cart should go.
Unread 09-02-2005, 23:37
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Keep in mind that the 75RPM on the datasheet is with no load. Under load, they will run a lot slower. Also, teams have been reporting that some of the van door motors have had a free speed as low as 50RPM.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Van door torque curves Bolotov Motors 1 05-02-2005 09:10
Motor Torque Question troy_573 Motors 13 22-01-2005 23:53
Question of the Week!!! (7/19/04) Andy Grady General Forum 23 23-07-2004 13:21
Question of the Week!!! (6/14/04) Andy Grady General Forum 23 01-07-2004 15:54
van door question archiver 2000 1 23-06-2002 22:27
