Go to Post I'm not the programmer, thank god. - Veselin Kolev [more]
Unread 07-02-2005, 02:56
HPA_Robotics_13 HPA_Robotics_13 is offline
#833 Team Captain
AKA: Ben Honey
#0833 (HPA Robotics)
HPA_Robotics_13 will become famous soon enoughHPA_Robotics_13 will become famous soon enough
Send a message via AIM to HPA_Robotics_13 Send a message via MSN to HPA_Robotics_13
RC won't talk to CMUcam
Team 833 needs some help with their camera:
We can talk to the camera unit from our laptop via the DB9 connector. But we cannot get the RC to communicate with the camera, even using the default code.
We have disconnected the DB9 link. We have ensured the 7.2V battery is adequately charged.
Any help would be greatly appreciated (our programming team says that they have read all other threads about the camera system and no one else seems to have had this problem).
Unread 08-02-2005, 04:03
#833 Team Captain
AKA: Ben Honey
Re: RC won't talk to CMUcam
A message from my team's programmer's:
Please help!
(personally I know nothing about this stuff, so I can't say whether they're missing something obvious or not... the mechanical stuff is moving along at least... )
Unread 08-02-2005, 11:10
Electrical Engineer
Rookie Year: 1995
I would contact IFI about your problem. It sounds like you either have it installed/connected incorrectly or have a defective system.
Mike Betts
As easy as 355/113...
Unread 09-02-2005, 00:35
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
My advice: just mess with it, and in the meantime contact IFI and try to get another camera as it is kind of late in the season to be trying to make something potentially defective try to work.... I have had problems with the data link a few times, once it was a faulty pwm cable, the other times I just messed around a bit, and got it to work.
Unread 09-02-2005, 00:48
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Hi,
I didnt read anything mentioning the TTL port, if the camera is not connected to the TTL port on the rc it wouldnt work so basically the setup is something like this:
PWM1--> Camera: Power
Servo--> Camrra: Direction
TTL-->Camera:Communication
And make sure all the 3-pin wires have the black alligned with the little B on the camera board.
Hope this helps, my $0.02
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 11-02-2005, 10:31
RoboMom RoboMom is offline
people expediter on Team Kluge
AKA: Jenny Beatty, no relation
no team (they are all my teams)
RoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond repute
I'm hoping I'm in the right thread as there is a reason the my name is usually followed by the words "non-technical"....
I've got two teams having similar problems.
>>We are experiencing some problems with our camera setup. It seemed to work
with the provided program. Then, when we tried to hook it up to the robot
controller, we couldn't establish a connection. If an effort to debug the
problem, we tried to hook it back up the the computer. Now it won't
connect to that either. We've checked the computer output and the camera
output with an oscilloscope, and they both seem to be working. <<
Any advice? They are not CD users (but should be!)
Co-Founder of NEMO (Non-Engineering Mentor Organization) www.firstnemo.org
Volunteer Director, STEMaction, Inc. www.stemaction.org
FIRST Senior Mentor: Nov. 2004 to June 2009: "Experience is that marvelous thing that enables you to recognize a mistake when you make it again"
This is How I Work: http://www.chiefdelphi.com/media/papers/2862
Unread 17-02-2005, 14:43
jude's Avatar
jude jude is offline
#0116 (Epsilon Delta)
jude is on a distinguished road
Send a message via AIM to jude
We had an issue with the TTL wiring between the RC and the camera.
The 5V pin on the camera is 2 pins away from ground, and is not 3 pins away like it is on the RC. I think we also had to swap some wires around so the transmit from the RC was going into the receive on the camera.
- jude
Unread 17-02-2005, 23:08
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
be careful, there are a few versions of the camera default code. Try both usrSerial and PIC_serial (something close to these labels). We also had a few start up issues with the camera and it mainly was due to improper wiring at first. Then as we played with the software, the camera sometimes stopped communicating, but at least we new it was software.
Unread 18-02-2005, 08:38
silliewillie's Avatar
silliewillie silliewillie is offline
#1643 (Bob's Builders in Black)
Team Role: Animator
silliewillie is on a distinguished road
We had this problem too and I think I can help you out. The same thing was happening to us and we found out that the TTL-232 chip was bad. They're 10 bucks off IFI's site, and now everything works fine. The troubleshooter for this told us what was wrong...you can find that through the "TTL-232 Basic Board Troubleshooting" link at the top of this page: http://www.ifirobotics.com/camera.shtml
I hope this helps you out. Good luck.
CMUcam setup Ryan Collings Programming 26 13-01-2006 01:00
CMUCam not working. Matt Krass Programming 4 18-01-2005 14:08
CMUCam for drivers patTeam241 Technical Discussion 22 16-01-2005 01:21
Mars Rover on Car Talk! mightywombat Televised Robotics 2 18-05-2004 14:41
With all this talk about fairness... DanLevin247 General Forum 7 08-01-2003 12:48
