Go to Post Us, as adults, find ways to help the kids to make it happen. - aspiece [more]
Unread 08-02-2005, 17:02
team 507 team 507 is offline
team 507 is an unknown quantity at this point
how do you mount the accelerometer?
i know this may sound a little stupid, but im a rookie roboteer, and i need to know how to mount the accelerometer, can someone please help me?
Unread 08-02-2005, 20:13
Re: how do you mount the accelerometer?
Assuming you are talking about the TI accelerometer in the kit, the data sheet shows the orientation. http://www2.usfirst.org/2005comp/Spe...elerometer.pdf
Unread 09-02-2005, 13:17
thanks alot, but this isnt what i really had in mind, i need a diagram to show me how to mount it on the robot, depending on the build of the robot. and is there a special way you have to mount it;?sideways, right side up?plz help, im confuzzled.
Unread 09-02-2005, 13:31
The document Joe Ross pointed you to does answer your question. If you want to measure forward (or lateral) acceleration, look at the diagram at the top right corner of the page. If you want to measure vertical acceleration (or gravity), look at the bottom left.
Unread 10-02-2005, 07:54
oh, thank you
i wasnt paying attention, lol....but thank you alot you guys, you guys rock!!!
URGENT! We need help with the accelerometer lkdjm Electrical 5 11-02-2005 16:42
Accelerometer Wiring/Input DAN THE MAN Control System 1 06-02-2005 20:02
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
Example accelerometer code released. Kevin Watson Programming 0 20-01-2005 03:45
In need of plastic drill mount jjdebner General Forum 4 19-02-2004 20:56
