Go to Post One of our electrical engineers would bring his kids in every so often, so they could actually see their dad during build season. - Karthik [more]
Unread 06-02-2005, 17:06
rcubes85 rcubes85 is offline
no team (TBD)
rcubes85 is on a distinguished road
Send a message via AIM to rcubes85
Size Of control box
Hello hi
IS theres size limit to control box, of what is the recommended size for a good control box that has 4 joy sticks ? Has any one made theirs yet
you can run from the past
you can change the present
but you can't outrun the future
becuase what you do in the presents depicts your future
Unread 06-02-2005, 17:16
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Re: Size Of control box
Originally Posted by rcubes85
Hello hi
<R65> The Operator Interface Console designed by your team must fit on the 69" wide by 12" deep shelf in the Alliance Station and the radio modem connected to the Operator Interface must be able to reach the mounting bracket on the operator stations. Be sure to leave at least 48" of slack in the 9-pin cable.
Ricky Quinones
Director of Sales - VEX Robotics
Unread 06-02-2005, 21:45
Be aware ther is an emergency stop box taking up some of that 69", so make allowances.
http://www.chiefdelphi.com/forums/sh...72&postcount=3
Unread 09-02-2005, 15:32
magilson magilson is offline
#0857 (Superior Roboworks)
magilson is an unknown quantity at this point
if your box is exactly 12" deep and because of cables it overlaps the table top will they give you a hard time?
-Team 857 Electrical Engineer
-EE Undergrad Upperclassman at Michigan Technological University
Unread 12-02-2005, 11:35
Crazy_Ed's Avatar
Crazy_Ed Crazy_Ed is offline
Amature Progammer
AKA: Ed Orsi
#0710 (PAW)
Crazy_Ed has a little shameless behaviour in the past
Send a message via AIM to Crazy_Ed
Has anyone found the width of the shelf? My team really needs the width/depth of the actual shelf we have to build for our controls.
I came, I programmed, I tore my hair out.
Unread 12-02-2005, 12:02
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
The point of your control box overhanging the shelf is more of a problem for you then for FIRST. During Auton mode i have seen robots come from one side of the field directly across and hit at a high speed into the opposite alliance's drivers stations diamond plate wall. The result of this many times for control boxes is them falling to the floor. If your control box is all ready hanging over the edge of the shelf you have a much higher chance of having it fall to the floor. If this occurs and damages your control box or joysticks it is then up to you to fix them. I would suggest you to make a control unit that is smaller then the available space and to have some sort of grip feet on the bottom.
Please see the above posts 2 and 3 in this thread for the answers.
-Michael Dessingue
Unread 15-02-2005, 16:30
I'm not in any way worried it would fall off, I'm talking around an inch and a half. In any case it'll most likely way too much and have much too low a center of gravity to fall off because of an autonomous robot.
Unread 18-02-2005, 10:04
KimT KimT is offline
I Know John Galt
#0159
KimT is an unknown quantity at this point
Along these lines, we have a joystick that is much easier to control if it can be held in the hand. Is this allowed, or does everything have to be locked into our operator interface?
Unread 18-02-2005, 10:22
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
If it can be quick disconnected from the OI, I believe it would be allowed.
If it can be left sitting on the shelf, I believe it would be allowed.
If there is a wire running between you and the OI, that would not be allowed.
I know other teams have done human mounted controls, but don't remember the specifics of them. The intent of the "stand back 3 feet rule" is to make it clear that the robot is running in autonomous.
Wetzel
pic: a control box CD47-Bot Extra Discussion 30 16-03-2004 00:08
Control Box Sizes InnoVaZiAn DJ Control System 8 20-02-2004 18:00
Box Control Tton General Forum 2 12-02-2003 23:38
control box size gail OCCRA 2 24-09-2002 05:30
control box archiver 2000 8 24-06-2002 00:20
