Go to Post John is the king of vague, but then again he looks much better at a distance than he does up close :D - Rich Kressly [more]
Unread 09-02-2005, 18:01
SpeakerSilenced SpeakerSilenced is offline
Programming/Electrical Team Member
#0219 (Team Impact)
SpeakerSilenced is an unknown quantity at this point
Send a message via AIM to SpeakerSilenced
How do you hook up the camera?
How do you *exactly* connect the camera to the board, there must be some type of input you need to hook it up to. And then how do you connect it to the Computer with and without the controller board. We have the servos and stuff already mounted.
My team and I find the instructions in other places confusing and I dont want to plug in the power through the wrong place -_-
Thanks in advance.
Unread 09-02-2005, 23:01
Electrical Engineer
Rookie Year: 1995
Re: How do you hook up the camera?
Thanks in advance.
Follow the instruction in "GETTING STARTED, (and finished), WITH THE CMUCam2 VISION SENSOR" (filename: Start_Here-CMUcam2_fe.pdf).
Mike Betts
As easy as 355/113...
Unread 10-02-2005, 17:41
#0219 (Team Impact)
I meant exactly, I already knew about that. I dont understand them.
"I want to put a ding in the universe" - Steve Jobs
Unread 11-02-2005, 08:39
Would photos like those posted here help? I could take a few more showing additional components like the RC and servos connected.
http://www.chiefdelphi.com/forums/sh...38&postcount=2
Unread 11-02-2005, 12:11
#0219 (Team Impact)
That helps some... where does the TTL on the R232 go? into the TTL of the camera board?
And how do you hook it up to calibrate it and/or on the robot?
Unread 11-02-2005, 12:46
Gal Longin's Avatar
Gal Longin Gal Longin is offline
Gal L.
#1578 (IsraBot)
Gal Longin is an unknown quantity at this point
Send a message via ICQ to Gal Longin Send a message via AIM to Gal Longin Send a message via MSN to Gal Longin Send a message via Yahoo to Gal Longin
How do I hook up the camera exactly ? Do I connect it directly to the servos or should I connect the servos to the RC ? should I allow the camera to be move by a servo left and right or should I try to mount it without a servo and let the robot motors control it's left-right movement? what is the best way to do this?
Does it make sense to connect the servos header from the CMUCam into the RC analog inputs and send the signal to the servos using the PWM outputs on the RC so i control and monitor the camera's movement?
Please help me, I'm really confused .
"Only two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." -Albert Einstein.
2005 Israel regional Finalist
2005 Israel regional Johnson & Johnson Sportmanship Award
2005 Israel regional Website Award
Unread 11-02-2005, 21:38
#0219 (Team Impact)
I guess im not the only one -_-
Unread 11-02-2005, 22:28
Electrical Engineer
Rookie Year: 1995
Did either of you read the file I referenced in my last post?
Mike Betts
Unread 11-02-2005, 22:32
Electrical Engineer
Rookie Year: 1995
And I meant exactly... What page and paragraph do you not understand... I will try and help if I can...
Excuse me for being curt but I really don't beilive you have read the documentation...
Mike Betts
Unread 13-02-2005, 01:59
#0219 (Team Impact)
I have, and I find them confusing. Like I stated to begin with.
Unread 13-02-2005, 13:08
Here are a couple of other photos to help. The servos are driven by the camera by those wires at the top. We had to reverse how the camera drove the servos, but you cannot quite see the jumper used in the photo.
There are two different ways we hookup the CMU camera:
1) to a PC to run the CMU GUI to get the calibration numbers and to test the camera. At the regional events the FIRST staff will give you the calibration numbers. These numbers have to be typed into the CMU camera code (v2.4). The GUI is in the IFI Robotics download
http://www.ifirobotics.com/docs/cmuc...-software1.zip
You'll find the GUI under the folders Software\CMUcam2GUI_fe\stand_alone and is called CMUcam2GUI_fe.jar
2) to the RC to drive the robot.
You cannot have the camera hooked up to both the PC and the RC at the same time or it just won't work.
ID:	2952  Click image for larger version
Unread 13-02-2005, 22:59
#0219 (Team Impact)
Alright, that anwsers everything. Thanks!
Unread 14-02-2005, 03:36
Calvin Calvin is offline
Calvin has a spectacular aura aboutCalvin has a spectacular aura about
Image I made for my Team, (might be helpful)
How to connect TTL
Unread 14-02-2005, 14:41
capenga's Avatar
capenga capenga is offline
Penga boy
AKA: Giovane
#1156 (Under Control)
capenga is an unknown quantity at this point
Send a message via ICQ to capenga Send a message via MSN to capenga
Arrow Re: How do you hook up the camera?
Seems to be a dumb question, but i'll do it:
your camera are working? (to the teams that have posted the photos)
Ignore alien orders.
Unread 15-02-2005, 09:45
Yes, our camera is working.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Unresponsive camera neilsonster Programming 9 17-02-2005 08:51
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
YMTC: Super Duper Hook! Natchez You Make The Call 7 14-12-2004 20:50
