Go to Post It doesn't matter if you write a thousand lines of code for a robot, if you didn't teach and/or inspire the HS students as you did it then you are not a mentor. - JamesBrown [more]
Unread 09-02-2005, 18:46
slickguy2007 slickguy2007 is offline
Copioli is the man!!!
FRC #1403 (Cougar Robotics)
slickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond repute
Send a message via AIM to slickguy2007
Autonomous Question.....
Has anyone actually gotten their robot to cap during autonomous yet? I am sure that this has already been asked somewhere out there(sorry if it has), but I am really curious. The camera code and stuff has been difficult to figure out and I wanted to know if our team was the only the one having this problem. Also what else, if anything, do you plan on having your robot do during autonomous?
GO 1403!!!
Unread 09-02-2005, 20:27
newgrl101's Avatar
newgrl101 newgrl101 is offline
AKA: Glory
FRC #0696 (Circuit Breakers)
newgrl101 is on a distinguished road
Send a message via AIM to newgrl101
Re: Autonomous Question.....
Well, we have programmed our robot to do everything we can in autonomous but we have on and off switches to match the conditions. Most of our work with the camera has been tested and it works except for actually capping the tetras because we don't have a field or a fully built arm yet. It is a hard process to calibrate the camera especially finding the exact numbers of the color during testing but with a lot of paint coats and hours of work, you can make it work.
Good Luck
Unread 09-02-2005, 20:35
skillinp's Avatar
skillinp skillinp is offline
FRC #1388 (Eagle Robotics)
skillinp is an unknown quantity at this point
we have gotten to the point of picking them up, but we haven't capped anything because the yellow triangle at the base of the goals hasn't been attached yet.
There's no honorable way to kill, no gentle way to destroy. There is nothing good in war. Except its ending.
Abraham Lincoln
"The Savage Curtain"
Unread 09-02-2005, 21:03
Collmandoman Collmandoman is offline
Post-A-Holic
Collmandoman has a spectacular aura aboutCollmandoman has a spectacular aura aboutCollmandoman has a spectacular aura about
first one to post a video will recieve E-props
Unread 09-02-2005, 21:06
Post-A-Holic
also, is anybody attempting this with only a single axis camera mount?
Unread 09-02-2005, 23:04
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
for all of those who want to cap during auton. how are you going to tell the cameral to switch from tracking green to yellow. Im thinking a modified limit switch inside the arm. any thoughts?
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
Yes another autonomous question. Wizang Programming 7 04-02-2005 03:31
A little question about the autonomous mode Anton Programming 4 18-01-2005 14:08
Autonomous testing question tml240 Programming 8 24-02-2004 16:12
