Go to Post Pneumatic components always give me gas... - Alan Anderson [more]
Unread 09-02-2005, 21:30
Calling Incorrect Interrupt Handler
I'm having a few problems with my program, and I've spent quite a while trying to figure out how to fix them, to no avail.
I am using Kevin Watson's encoder driver. I did encoder testing on the EDU RC, and everything worked fine. I switched to the FRC RC, and I have hooked up the encoders as stated in the file description. So, DIG IN 1 should cause interupt 2, which will in turn call the Left_Encoder_Int_Handler(). I do not have an encoder hooked up as the right side encoder (dig in 2) The encoder itself is working fine, but it increments the right side variable instead of the left. Also, when I plug the encoder into dig in 2, which should handle the right side encoder, neither right or left gets incremented. I have configured my phase B pins in the correct way, but I dont think this is part of the problem. Does anyone know what may be wrong?
Unread 09-02-2005, 22:48
Electrical Engineer
Rookie Year: 1995
Re: Calling Incorrect Interrupt Handler
Tom,
On the RC, DIO1 is tied to interrupt 1 and DIO2 is tied to interrupt2.
Are you trying to run the EDU code on the RC? If so, be advised that they are not compatible.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 09-02-2005, 23:00
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
I beg to differ.
only the first 6 digital I/O pins (pins 1 – 6) can be set to generate interrupts (INT2 – INT7)
The interrupts (INT2 and INT3) on pins 1 and 2 are separate and independently configurable. However, the interrupts (INT4, INT5, INT6 and INT7) on pins 3 – 6 are ganged together.
Both of those quotes are from the Interrupts for Dummies white paper, but I know I've seen it in official documentation, too.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 09-02-2005, 23:05
Mike,
I am not using edu code on the bot, at the time i was using Kevin's EDU-Encoders workspace, but now I am using the FRC-Encoders.
I am pretty sure pin 1 is INT2
From user_routines_fast.c...
if (INTCON3bits.INT2IF && INTCON3bits.INT2IE)       /* The INT2 pin is RB2/DIG I/O 1. */
    INTCON3bits.INT2IF = 0;
	Left_Encoder_Int_Handler(); // call the interrupt 1 handler (in encoder.c)
  else if (INTCON3bits.INT3IF && INTCON3bits.INT3IE)  /* The INT3 pin is RB3/DIG I/O 2. */
    INTCON3bits.INT3IF = 0;
	Right_Encoder_Int_Handler(); // call the interrupt 2 handler (in encoder.c)
Unread 09-02-2005, 23:42
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Originally Posted by Tom Bottiglieri
...I am pretty sure pin 1 is INT2...
Here's the PIC18F8520 to robot controller pin mapping.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-02-2005, 20:00
ScottWolchok ScottWolchok is offline
Pwnt.
#0217 (ThunderChickens)
ScottWolchok will become famous soon enoughScottWolchok will become famous soon enough
Send a message via AIM to ScottWolchok
I am having the exact same problem. I could swear that the encoders even worked correctly a day or two ago! I have checked the connections several times - the left encoder's phase A is definitely on pin 1, and its phase B is on pin 6, but turning the left encoder increments the right encoder count and turning the right encoder does nothing at all. However, the left encoder count does change from 0 to -1 when the right encoder count is less than 0. I have gone so far as to simply compile and load the Navigation_FRC demo from kevin.org, but I still experience the problem. I have also switched encoders, encoder cables, and FRCs. Can anyone offer some advice?
Unread 12-02-2005, 21:15
Don Reid Don Reid is offline
Don Reid will become famous soon enough
This sounds strangely like a problem I just had. It turned out that nothing was wrong with the encoder code (of course), just a printf statement.
Note that Get_Right_Encoder_count() returns a long! So you cannot
just put it into a printf with a %d type. If you have 2 %ds, you will
get 1/2 of the long for each one, the upper part is usually 0.
The thing to do is to use %ld to let printf know to expect a long value.
Don Reid
Unread 14-02-2005, 18:06
Pwnt.
Yeah, that's exactly it. I casted the return values to int, and they still seem to be backwards, but I just swapped the wiring and carried on.
Timer interrupt hic-cupping - HELP roknjohn Programming 9 15-03-2004 17:56
Interrupt Handlers and Variable Scope kaszeta Programming 2 14-02-2004 18:30
Interrupts Questions mightywombat Programming 0 03-01-2004 14:50
What is an interrupt handler? Adam Y. Programming 7 14-08-2003 10:26
