Go to Post "Mentors Only Work When Being Calibrated". - Calvin Hartley [more]
Unread 09-02-2005, 21:50
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Exclamation Warning: Microchip's printf() Picky
I found tonight that when using Microchip's printf(), and the format string does not end in "\r", then it may cause the green-orange blinking on the program LED on the controller.
Make sure all your calls end their lines correctly.
Unread 09-02-2005, 21:54
Re: Warning: Microchip's printf() Picky
If this is true.. I think you saved me hours of frustration.
I was getting a blinky blinky code state light, and I think its because i had /n instead of /r .
Did you run into this problem or something similar?
Unread 09-02-2005, 22:11
Ryan Cumings's Avatar
Ryan Cumings Ryan Cumings is offline
Programmer and University Rejected
#0134 (Team Discovery)
Ryan Cumings is an unknown quantity at this point
Send a message via AIM to Ryan Cumings
I found that out when I re-used some code from last year.. Does anyone know why they changed it?
Suddenly being rejected from college feels right during the build season. Now I am a mentor.
Unread 10-02-2005, 15:21
You can use IFI's printf if you like. It's still included with both versions of the default code. The difference now is that you can choose to use IFI's or Microchip's.
Unread 13-02-2005, 19:26
probizzle's Avatar
probizzle probizzle is offline
AKA: Prabhas Pokharel
#0639 (Code Red)
probizzle will become famous soon enoughprobizzle will become famous soon enough
Send a message via AIM to probizzle
Also,
make SURE no stray printfs are being calling before Initialize_Serial_Comms() is called.
If you do this, your rc will go into red-green led mode every time you reset it. So you'll have to end up downloading your code ALL the time.
(I'm assuming ifi-loader will do these initializations for you the time you are downloading code, and as this won't happen later, you get the crash. dunno though.)
Code Red Team 639 Winners of the 2005 FingerLakes Regional with 191 and 494.
http://pset.deu83.com << my baby
http://www.setgame.com/set/ << it's mother
Unread 13-02-2005, 19:27
probizzle's Avatar
#0639 (Code Red)
Also,
make SURE no stray printfs are being called before Initialize_Serial_Comms() is called.
(I'm assuming ifi-loader will do these initializations for you the time you are downloading code, and as this won't happen later, you get the crash. dunno though, someone wanna check?)
Printf symbol undefined? Help schenkin Programming 3 08-02-2005 16:14
printf problem miketwalker Programming 7 31-01-2005 13:19
Default Code and printf WilsonDJ00 Programming 2 22-01-2005 16:39
Anyone with a replacement Printf? Larry Barello Programming 5 19-03-2004 02:20
Printf warning during compile? actorindp Programming 4 20-02-2004 17:02
