Re: Unknown Blinky-light type Errors.
Also, I noticed http://www.chiefdelphi.com/forums/sh...threadid=34301. Did that fix it for you? (I will try to check all my printfs tomorrow). |
I'd need to see the whole project to track a problem like this one down.
I'd also like to know what external sensors you have hooked up and the theoretical (or actual) interrupts per second you expect. |
I was getting the same error for a while when I was trying to get interrupts working. I eventually abandoned that at about week 3 and just went with polling. Not sure what caused the problem...
It'll probably end up being an after season project. |
The ZIP version is at http://endeavour.zapto.org/astro73/tg_2005.zip. I couldn't get it under 100 KB. |
(see my other post for other half.)
The problem seems to be fixed by removing the double calls to OpenADC(). Check gyro.c and ifi_utilities.c for the implementation. |
#7
So you found and solved the problem.
That's good news! |
#8
-Kevin |
#9
In the old version of the gyro code, the initialize function would call OpenADC() but not CloseADC(), leaving the A/D converter open. If you wanted to get an analog value by calling IFI's function, it would also call OpenADC(), which is probably bad, and CloseADC(), also bad. The interupt that handled the gyro doesn't call anything other than to get the value. The only way this would work is if Microchip's code kept track of nested Opening/closing of the ADC. The way I solved this is that I put Set_Analog_Channels() in an Initialize_Analog_Channels() (or similar) call, which would call OpenADC(). Then I changed Get_Analog_Value() so it set the analog channel without opening/closing. I also changed the Gyro interupt so that it would switch channels as well. I haven't checked this yet for the new code, I'm in the process of merging them. And a few of the function names are probably wrong. |
| Light Sensor Type, Please Help! | Alexander McGee | Electrical | 7 | 20-11-2004 21:48 |
| How many users does it take to change a Light Bulb? | Matt Attallah | Chit-Chat | 4 | 04-09-2004 20:59 |
| Please...no more steenkin' light! | Andrew | General Forum | 37 | 17-04-2003 23:06 |
| light visibility | Erinn888 | General Forum | 30 | 17-02-2003 15:56 |
| Important info about light | Jay Lundy | Technical Discussion | 10 | 12-04-2002 11:37 |
