Go to Post Now really, who would want to try and go against Andy Baker? That's like trying to single-handedly outscore 25, 254, and your choice of triplet with a shopping cart. - Billfred [more]
Unread 10-02-2005, 02:40
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: Pneumatic Air Tanks
In terms of pressure and/or efficiency, probably not. Having them in parallel just means it takes up less space length wise.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 10-02-2005, 02:43
supertw supertw is offline
supertw will become famous soon enough
the way i see it is its like pouring from two soda bottles at one time compared to pouring from a larger bottle, and clearly the first case would work faster
Unread 10-02-2005, 02:51
24 Hours of LeMons?
The increase isn't significant (or at least from what i've experienced). The size of the pipe still limits the air flow, even if you put them in series. The only way to achieve higher air flow is to increase the PSI (the max is 120 anyways) or get bigger pipes.
If you had bigger pipes, then connecting the tanks in series would definetaly increase the air flow rate, since the bottleneck is now at the accumulator tanks.
For example, with your soda bottle example, try connecing them to a hose the size of the bottle's neck and empty them out, there won't be much of a difference if you had one big bottle, or two small ones connected in series.
Higher PSI in air Tanks Projectchon Pneumatics 8 01-02-2005 15:05
How to make Pneumatics use less air sanddrag Pneumatics 1 16-02-2004 15:50
More than two air tanks? Mercutio Pneumatics 6 10-02-2004 16:07
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
More than 2 pneumatic tanks? kangarue23 Pneumatics 10 01-05-2002 12:14
