Re: Van Door motor help
Just another note on the Van Door Motor... The shaft itself is 11mm, which is close enough to 7/16" to work. We tried to find an 11mm drill bit locally, but could only find them through McMaster or similar sites. To mount a sprocket on the shaft, we used a 5/8" bore sprocket and made a spacer to fit between it and the shaft. We then drilled through all three and pinned them together. (5/32 dowel pin)
Bengineer GUS, Team 228 |
the van door motor is immensly more powerful than the window motor. we set up part of our arm today, the window motor could not even lift the 12 pound arm up, but the van door motor swung it around at a dangerous speed.
Does anyone know an effective method for combatting the van door motor's backdriveability? As in, so it will suspend an arm with a tetra, requiring about 10ish Nm on the motor? The only good way we could think of was having it lift the arm along with the non-backdriveable window motor, but it is a nuisance getting them to run at the same speed. Any thoughts?
gearing it to the point that the motor at stall or idle will stop the arm works, but it will slow down the movement speed of you parts (arm i am guessing). it will give you More torque, but someone told me that an arm that takes more than 6 seconds to move from bottom to high enough to cap will only be able to cap 3 goals in a game (not sure on the math).
| Van door torque curves | Bolotov | Motors | 1 | 05-02-2005 09:10 |
| Van Door Motor Thermal Overload Protection | bigqueue | Motors | 1 | 23-02-2004 07:16 |
| Attn Wildstang: Found your van | Wetzel | Chit-Chat | 4 | 21-04-2003 21:41 |
| We can't compete, need van door motor | archiver | 2000 | 1 | 23-06-2002 22:59 |
| van door question | archiver | 2000 | 1 | 23-06-2002 22:27 |
