Go to Post we are all in the same boat. We'll adapt and deal with the challange. No need nashing teeth over the little stuff... - wilsonmw04 [more]
Go Back   Chief Delphi > FIRST > General Forum > FIRST E-Mail Blast Archive
Unread 09-02-2005, 06:05
Jizvonius's Avatar
Jizvonius Jizvonius is offline
AKA: Jevawn Roberts
FRC #1002 (CircuitRunners)
Jizvonius is just really niceJizvonius is just really niceJizvonius is just really niceJizvonius is just really nice
Send a message via AIM to Jizvonius
Re: **FIRST EMAIL**/Fisher-Price Motor Information
In terms of using the FP's to servo an arm mechanism, there is a definite issue with using the motor itself to hold the arm in a position(stalling the motor and allowing heat build up). Some systems, however, use other mechanisms(worm gear, ratchet,...some crazy new idea) to limit the back-driving or at least the torque reqired by the motor to prevent it. This limits the heat generation in the motor as it requires less current to hold position. If you are careful you can come relatively close to balancing the heat transfer out of the motor with the heat generation.
Long story short, FP's can power arm mechanisms very well but considerations must be made for the properties of the motor.
Regarding the FIRST email, the voltage limit will increase the chances of your FP's living for obvious heat generation reasons. Some teams run at 12V safely, many don't. If you are unsure and the FP's are integral parts of your robot's design, better to be safe then sorry.
BTW how about temp sensors on motors that control limiting voltage? (if you really want to squeeze all the power you can get with a smaller safety margin) You would need a reference temp for when you are close to burning out the motor but just at thought. Kinda like a smart heat sink/fan for your processor)
Jevawn Roberts
Georgia Tech Mechanical Engineering Senior
Co-Leader - GT FIRST
gtfirst@robojackets.org
1997-2007 w00t for robots!
108-132-408-832-1002
5 teams worth of head scratching
Unread 09-02-2005, 06:41
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
I am not an engineer, but I would like to suggest that teams be very careful that any arm being moved by the Fisher Price motors is not pushing on something immovable (like the ground). It is sometimes easy not to notice that the motors are straining if there is no motion. You need to alert your drivers to be very careful about that.
Also I suspect that some teams are trying to deal with large forces (such as a vision tetra on the end of a 10 foot arm) without gearing down enough. Calculate out how much force it takes to lift those tetras on a long arm.
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 09-02-2005, 12:03
HPA_Robotics_13 HPA_Robotics_13 is offline
#833 Team Captain
AKA: Ben Honey
#0833 (HPA Robotics)
HPA_Robotics_13 will become famous soon enoughHPA_Robotics_13 will become famous soon enough
Send a message via AIM to HPA_Robotics_13 Send a message via MSN to HPA_Robotics_13
So how is team 1072 making sure that the motor doesn't stall? I suppose you have to have the torque from the arm when the arm is in the position you want, transferred to some other mechanism. With our arm design, and the way that team 833 has played FIRST in the past, I know that our arm will need to be up in the air many many times, for long periods of time.
So if you do a gear reduction from the motor to your arms pivot point this will reduce the strain on the motor at stall? is 7:1 enough? Also, if you put a heatsink on the motor along with a muffin fan, can you make up for the problem of heat enough that there shouldn't be a problem or are there other issues than the heat?
What is the reason that this is not an issue for the other motors provided?
Unread 09-02-2005, 13:08
Jizvonius's Avatar
AKA: Jevawn Roberts
I assume that you mean 1:7 after the FP gearbox supplied in the kit. I can't answer that conclusively without knowing the properties of your arm. Our team always calculates for worst case scenario, which would be in this case the arm being horizontal and fully extended with a full load (We would never do that, but the arm should withstand it very briefly without burning motors).
A heatsink and fan will cool the motor case but not the wire coils in the motor(at least not directly or fast enough). It will help but not as much as some think. Increased air flow through the motor along the surface of the coils is probably the best thing for this situation. Not sure what the best way to pull that off is. Any suggestions?
Jevawn Roberts
Unread 09-02-2005, 13:46
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Do a search for posts by 254 members... they explained in great detail how they made their arm work. Im pretty sure it was Jay Lundy.
2001-2004: Team 100
2006-Present: Team 254
Unread 09-02-2005, 14:45
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Well we've finished our arm driven by two FP's and now I'm feeling nervous. We've built a new gearbox for a total reduction of 1700:1 and it works great and only draws 15 A (each) when picking up a tetra at the end of its 5' arm. However, that's without modifying the program to limit it to 6 V. I wonder if it will still work?? Theoretically 15 Amps at 12 volts should translate to 30 Amps at 6 Volts, but unfortunately heating follows I^2*R which means we'll end up with more heat loss This sucks!
Unread 09-02-2005, 14:47
#833 Team Captain
AKA: Ben Honey
Jizvonius, how would holding the arm at it's full position - say, at a 40-50 degree angle up - be much different than holding it straight out? I understand that the torque will be a little bit less because of the angle, and the center of mass is closer to the pivot, but is it that big of a difference on a 5-foot arm?
From what I can tell it is a very sketchy thing to use the fisher-price motors to power an arm that needs to able to stop at various angles to retrieve, manipulate, and place tetras from loading stations and onto different height goals.
Unread 10-02-2005, 13:19
Jizvonius's Avatar
AKA: Jevawn Roberts
I can't say that the difference will be that big in a 5 foot arm. However, some teams have arms much larger than that.
The statements that i made earlier were general. They were based on the fact that I've seen many an arm work well with FPs powering joints. Holding position solely with the FP is indeed sketchy. I was just saying that with a little ingenuity some of the load can be taken off the FP to make a reliable arm pivot.
Some ideas that i had for limiting backdriving of the pivot to save FPs.
-generic worm gear system. (lead angle about 20 degrees saves some efficiency but increases backdriving)
-Servo/piston controlled gear brake near motor side of gearbox
-piston FP combo with piston regulated to lower pressure(helps with movement and holding position)
Feel free to call me crazy. It's happened before. Just back it up with something.
Jevawn Roberts
Unread 10-02-2005, 13:26
Alex1072 Alex1072 is offline
AKA: Alex
#1072 (Harker Robotics Team)
Alex1072 is an unknown quantity at this point
Send a message via AIM to Alex1072 Send a message via Yahoo to Alex1072
We're not using it for rotation, so our problem is much simpler. Since the new specs of the van door came out, we redesigned our elevator to be powered by 2 fisher prices. Basically we're using two of them at a reletivly low spool diameter to make SURE that it won't stall. I think our grabber would actually break before it stalls.
EDIT: I just remembered that one solution we came up with in our brainstorming (at one point were were thinking of doing a rotating arm), we were going to extend the bar past the pivot point and attach a cable to the back end, and a point equally far away from the pivot at the front of the arm. A cable would go down to a spool, wrap around it a bunch of times, and then go back up the other attachment point. That may pose entanglement issues though. Just a though.
Alex
President
Team 1072 Harker Robotics
Unread 10-02-2005, 15:32
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Probably too late to pull it off, but if you used the DeWalt transmission for the FP, you could leave in the anti-backdrive pins and just not run the motor when you don't need to.
Unread 10-02-2005, 16:03
#833 Team Captain
AKA: Ben Honey
What would any of you say about having a reduction on your system so great that you would just rely on the torque it takes to backdrive the motor being greater than the force of the tetra and your arm? This way you do not stall the motor, and it holds position.
Unread 11-02-2005, 08:00
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Back on topic - I.E. the unavailability of the kit FP.
They promised more information to follow, yet none has come this way.
All who plan to use - or misuse - the FP motor had better e-mail frcteams@usfirst.org and Sharon Gele <sgele@usfirst.org> in particular and implore them to let us use last year's motor as well. That would solve the availability problem and the 6v motor in a 12v system problems as well.
I do not understand why they have not done so already.
This message is hidden because Jack Jones is on your ignore list.
Unread 11-02-2005, 08:50
Dr.Bot
Posts: n/a
Some people asked about the 2004 254 robot. Yes, we did use The FP motors last year to power our arm, and no we are not using them for our arm this year. It was our original intent to use them, but we have changed our design, based on the FIRST blast information. We will be using the FP motors as supplied by first in our drive drain, but will use in tandem with other motors.
We are planning to use them through a unmodified PWM - We have no plans at this time to regulate the voltage down to six volts before sending it to the PWM, because 1) we don't know if that's legal (would require addition of some inexpensive electronics -a couple of high amperage solid state voltage
regulators) 2) We don't know if the PWMs would work correctly, if only 6 volts is being fed into them( I don't see why they wouldn't, but I am not a EE!). Our plan is to run the FPs and replace or remove them if they fail. We did have to fine tune our gearing so that the other motor overdrives the FP and not the other way around. We are estimating the FPs are contributing < 25% of the power to our drive.
To everyone struggling with this - good luck. Overcoming limitations in your
supplied equipment is part of the challenge.
Unread 11-02-2005, 10:41
President, VEX Robotics, Inc.
Jack,
Please relax. I assure you that FIRST (and others) are doing everything they can to get the situation resolved. It is the number one priority for the engineering department at FIRST. Fisher-Price and Mabuchi are also scrambling to get a solution. Things are not always as simple as they seem.
-Paul
Unread 11-02-2005, 17:12
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Thanks Paul.
I have one question. Everyone says that the FPs will inevitable fail. Besides JVN's beating, has anyone actually had this year's motor fail yet? If so, can we hear about the situation it was used in and the failure that occurred?
Use of the fisher price motor ALONE Some Guy Motors 6 03-02-2005 08:55
Need Fisher Price Motors kevinw Motors 1 13-02-2003 18:44
Multiple Fisher Price Motors? authgeek1218 Motors 5 10-01-2003 10:48
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
New Fisher Price Motor - IMPORTANT Paul Copioli Motors 6 08-02-2002 13:35
