Go to Post Someone should make FIRST fortune cookies, because I think I just thought of a good one. - artdutra04 [more]
Unread 10-02-2005, 16:32
psquared psquared is offline
psquared is an unknown quantity at this point
Accelerometer: Analog or Digital?
We had our accelerometer connected to an Analog port, which we thought it was, but when we printfed the Get_Analog_Value(blah) it showed up some huge number like 17439, the value that we made get_analog_value go to was a double value, and we printfed with %d, when we moved the accelerometer no value changed
should it be an int instead of double?
do you think our connections might be wrong?
should it be digital instead?
or any other thing it might be?
thanks for the help
Chantilly 612
Unread 10-02-2005, 16:37
Re: Accelerometer: Analog or Digital?
The accelerometer is definitely an analog sensor. Make sure you have the wires connected correctly; the color code is nonstandard. Black goes to +5 volt power, red goes to ground, and white is the output to the RC.
The value returned by the Get_Analog_Value() function is a ten-bit integer. It can range from 0 to 1023.
Unread 10-02-2005, 16:38
thanks for the help
Chantilly 612
You are correct it is an analog input.
The easiest mistake to make is the colors of the wires on the accelerometer are not normal. Check the spec sheet for how they should be swapped around.
Get_Analog_Value returns an int.
When you printf make sure you are printing an int.
The accelerometer should return a value in the neighborhood of
--730 when facing up
--512 when horizontal
--340 when facing down
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
Analog / Digital IO Connectors Aidan F. Browne Control System 4 06-02-2005 22:26
Example accelerometer code released. Kevin Watson Programming 0 20-01-2005 03:45
Dynamic Input/Output Changing Paolo Control System 6 23-09-2004 19:09
