Re: Pneumatics-Code [and piston output length]
A pistons length is about 2 " longer than the throw when in closed position. Therefore a 4" throw would give a 6" in length piston closed or 10" when open. This is a rule of thumb and not exact. Smaller throws still need minimum 4 "
| Updated: Serial Port Driver Code | Kevin Watson | Programming | 4 | 05-02-2005 18:39 |
| Kevin Watson's encoder code with RPM output | MaxM | Programming | 2 | 05-02-2005 00:06 |
| Team THRUST - Kevin's Code and Camera Code Combine | Chris_Elston | Programming | 3 | 31-01-2005 22:28 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Rookie Programmer has question about the default code | DanL | Programming | 3 | 26-01-2002 19:59 |
