Go to Post "Don't worry, it's just a prototype." - Newo95 [more]
Unread 10-02-2005, 16:41
WhiteTiger WhiteTiger is offline
WhiteTiger will become famous soon enough
Electronics visible?
Another electronics question (and we couldnt find this one in the rules... )
last year we had to have the electronics visible, and we assumed the same for this year until we hit a design flaw that wouldn't happen if the electronics needed to be visible. In the rules, there is nothing (that we could find, anyway...) that says the electronics need to be visible. So do they need to be visible again this year, or can we keep our same design?
thanks!
Unread 10-02-2005, 16:50
Karthik1's Avatar
Karthik1 Karthik1 is offline
830 Alumni
AKA: Karthik Chokkaram
FRC #1504 (Desperate Penguins)
Karthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to all
Re: Electronics visible?
The LEDs in the robot controller needs to be visible and the breaker must be easily accessible.
"freedom is voluntary self control” Mahatma Gandhi
Unread 10-02-2005, 16:53
Hershey's Avatar
Hershey Hershey is offline
You can't name all of my positions!
AKA: Andrew
#1290 (Wolfgang Robotics)
Hershey can only hope to improve
Send a message via AIM to Hershey
Well, as far as I know, it's not stated in the rules, but it would be a good idea to keep you robot controller's LEDs visible. We found it could be useful at the end of a match when your robot does something totally unexpected and you want to know what happened. Next, you look at the robot controller's LEDs (which are still being powered by the backup battery) and you notice the problem with a red LED. You go back to your pit area, fix the problem, and it doesn't happen again. If you're looking for a material for see-through material, try lexan. It was protective enough for us last year and we were still able to see our LEDs on the robot controller.
Unread 10-02-2005, 16:54
Yeah, the RC status lights must be visible. But whether or not the rest of the electronics are visible during a match, you definitely want the robot to be inspectable at competition. I wouldn't hide things so well that you have to disconnect parts in order to get to the electronics.
Unread 10-02-2005, 17:38
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
In section 5 - The Robot, check out R57 and R58.
R57 says that the RC indicator lights must be visible at inspection and during the competition.
R58 says that all circuit breakers must be visible for inspection.
"Them's the rules"
Warren B
Pool Noodles. They're not just for bumpers anymore.
Unread 10-02-2005, 18:56
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Not mentioned anywhere else, the spikes and victors have lights that although they don't need to be visible, helped us out more than once.
I think, in summary, that it's part rule, part good idea.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 10-02-2005, 21:45
yea thanks guys!
knowing our team, we'll need to make MANY adjustments...
It's easy enough though...i think we have an idea to make most of the electronics visible and the rest easily accessible
if anyone was in Annapolis last year, we were the team that had a drill motor brake on us, and as a result, only half our robot worked in the last competition...
so we know the importance of easy maintenance
Unread 10-02-2005, 22:02
MasonMM's Avatar
MasonMM MasonMM is offline
AKA: Mason Markee
FRC #0118 (Robonauts)
MasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond repute
I remember last year the inspectors were also looking to make sure out pump valve was clearly accessable... we had it buried within our drivetrain and although they didn't disqualify us, they didn't seem to like the idea.
Unread 11-02-2005, 02:01
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
They also wanted the "Robot Reset" button accessable when they inspected us at Sac.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 11-02-2005, 02:29
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Fortunately, if that's a problem, there are header pins on the RC to which you can connect external switches to replace both the Program and Reset switches.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 11-02-2005, 03:17
FRC #0973 (GRR)
Electrically thats possible .. if the inspectors allow it is another story.
2011: ???
Unread 11-02-2005, 08:16
That's why they are part of the RC. Please make electronics visible, it makes an inspection much easier and it willhelp you when a problem arises. Don't forget a potential finals alliance partner will want to know you can make repairs quickly and diagnose problems should they arise.
Unread 11-02-2005, 09:34
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
<R63> A remote reset and remote programming switch may be wired to the Robot Controller’s RESET/PROG header. Any switch may be used. See the Robot Controller Reference Guide for wiring information.
There is no requirement for access to the RESET button this year. But it is still a good idea
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 11-02-2005, 11:52
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Please please please take this to heart. It only takes one "we have an elimination match in FIVE MINUTES!!!" with one bad inaccessible wire/pwm cable/fuse/radio/whatever to ruin an entire year...
No one will tell you that you need to spend all your time laying out your robot components, but do make sure you at least try to make things accessible.
-SlimBoJones...
Unread 14-02-2005, 23:54
DarkWombat DarkWombat is offline
#0840 (Aragon Robotics Team)
Team Role: Electrical
DarkWombat is an unknown quantity at this point
Hmm...well our team planned to get an aluminum hood that would cover the electronics and protect them during operation. However, the hood will be hinged on the side so that it can be easily opened up to access the electronics. So does this mean that we'll have to cut a slot open in the hood so that the LED's will be visible while we're competing? I'm getting mixed answers from this thread, I understand that we'll have to have the electronics ACCESSABLE, but do we also need to have the LED's visible so that they can be seen from a distance while the robot is in use (competing on the playing field)? Because I don't think that'd matter much, since if the LED's WERE visible you wouldn't be able to discern from twenty feet which LED was correpsonding a certain problem anyways.
So I guess the question is: can we use a protective shielding/hood to protect the electronics during operation, but which can also be easily removed to access the electronics componenets for inspection and while in the pit area?
Programming and Electronics — Getting Started Sidney San Martín Technical Discussion 7 12-01-2005 15:25
Books on electronics relating to robotics patrickrd Technical Discussion 1 15-05-2004 21:28
Covering Electronics shyra1353 Rules/Strategy 6 24-02-2004 22:23
Professional electronics board assembly [annotated collector's edition] Geoff General Forum 7 17-02-2004 21:57
Question about buying electronics _GP_ General Forum 5 01-02-2004 12:43
