Go to Post Adaptability is the key folks. Your job will not be the same 10 years from now (when I retire), or 20 years or 30 years from now. The tools and systems you use will change, and you must be able to adapt along with them. - Bill Moore [more]
Unread 10-02-2005, 19:05
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Pneumatics-Code [and piston output length]
I believe he is asking about how to control how long the piston extends in code. There is no easy way to do this without sensors, feedback, and multiple solenoids per cylinder. If it really is important, search multipositioning with cylinders for some help on the topic.
Team 1257
Unread 10-02-2005, 19:57
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
We did this last year. The key for us was a solenoid that centers when there is no power (Meaning if relay1_fwd == 0 and relay1_rev == 0, no air would move). Otherwise, you can use 2 solenoids: one as a go/no go, the other for direction. See the shoulder_* functions in grabber.c in the 1227 code for an example.
Unread 13-02-2005, 11:42
reilly reilly is offline
reilly is an unknown quantity at this point
Actually, I was refering to the only given cylinder that came with the kit, the pneumatics manual doesn't give the specs for the given cylinder [not all those you can order].
Is there any difference between throw and stoke?
P.S. Yes I was asking about pwm control: thank you for the coding tip [link].
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
Kevin Watson's encoder code with RPM output MaxM Programming 2 05-02-2005 00:06
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
