i need to find an anderson connector asap.
I can't seem to find some place to find an anderson connector. THe red connector thingy that goes onto the battery (connect thingy). i want the power cord with it too :-D. if you help me, thank you :-D
Re: i need to find an anderson connector asap.
I don't think you can buy it with the wire already crimped in, but you can buy the contact/housing package here www.powerwerx.com (50 Amp SB Series) and solder in new wire (there is some in the kit).
Grainger if nearby usually has the 50 amp connector in stock. They do not sell one with cables connected to it but as mentioned above you could easily attach your own. I would more suggest a combination of both. First crimp then solder. The crimp will give a good physical contact and will hold the wire, the solder will give a good electrical contact.
-Mike |
#7
If you visit the Powerwerx site and search around you will find a variety of documents on the this family of connectors and you will see that there are two types of connctors (high detent and normal) and two types of crimp for each. Choose Wisely. The one style is easily crimped with standard crimpers.
Remember that a good soldered connection is one that is mechanically sound to begin with. A poorly made connection, even one that is soldered has the potential for high resistance (relatively speaking) which means heat. I have seen these contacts get hot enough to melt the plastic holding the contacts in place. This is a domino effect which can only increase the resistance and heat over a short time and yes it might get hot enough to melt solder. Most electronic solder alloys will melt at just over 400 degrees. |
| where can i find these?? | jazzsaxman1988 | Programming | 3 | 05-02-2005 01:24 |
| How to find the moment of an arm | Matthew_H | Technical Discussion | 7 | 26-10-2004 12:20 |
| 3dmax - setting a display option that I can't find | DanL | 3D Animation and Competition | 5 | 05-01-2003 12:42 |
| Want to find out about other teams?? | archiver | 2001 | 0 | 24-06-2002 01:24 |
