Go to Post Force yourself now, today, to learn one new thing each day. When you lay down on your fluffy pillow at night, before you say your prayers, ask yourself if you have learned anything new. If the answer is "NO" then you better get up and find something. - Al Skierkiewicz [more]
Unread 10-02-2005, 20:34
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Camera Movement has Ceased
Okay, I have an interesting situation:
I hooked up the CMU cam a few days ago, powered up the bot, and it snapped to position as it should. I've since downloaded the camera code and had a teammate redo the assembly and it seems to have stopped driving the servo (essentially a few variables changed simultaneously, which is never a good situation to be in). My assembly is for up/down movement only (like the example mount) and the servo is connected to the pan port. No jumper settings have been altered. It does not snap to default when I power it up, nor does it resist if I try to gently move it. Any idea how to go about troubleshooting this?
Clarification: The power LED does come on.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 11-02-2005, 00:20
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Re: Camera Movement has Ceased
Well it shouldnt matter, but a) the design given to us only had pan not tilt and b) assuming you have a tilt servo you should plug it into the tilt port, rather than the pan port. Other than that.... No idea
Unread 11-02-2005, 10:22
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
have you tried changing servos?
just make sure that you connect the <left right> servo to pan and the <up down> servo to tilt.
if it just stopped moving (and it worked before with the same settings) i would also check the batteries.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Unresponsive camera neilsonster Programming 9 17-02-2005 08:51
NEED HELP WITH CAMERA MOVEMENT nm4 Programming 3 10-02-2005 17:17
camera tracks but no movement from Robot Stillen Programming 4 04-02-2005 17:16
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
