Go to Post We don't use fancy tools like that, but we might need some wood glue or something :) - MrForbes [more]
Unread 10-02-2005, 20:34
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Camera Movement has Ceased
Okay, I have an interesting situation:
I hooked up the CMU cam a few days ago, powered up the bot, and it snapped to position as it should. I've since downloaded the camera code and had a teammate redo the assembly and it seems to have stopped driving the servo (essentially a few variables changed simultaneously, which is never a good situation to be in). My assembly is for up/down movement only (like the example mount) and the servo is connected to the pan port. No jumper settings have been altered. It does not snap to default when I power it up, nor does it resist if I try to gently move it. Any idea how to go about troubleshooting this?
Clarification: The power LED does come on.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 11-02-2005, 00:20
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Re: Camera Movement has Ceased
Well it shouldnt matter, but a) the design given to us only had pan not tilt and b) assuming you have a tilt servo you should plug it into the tilt port, rather than the pan port. Other than that.... No idea
Unread 11-02-2005, 10:22
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
have you tried changing servos?
just make sure that you connect the <left right> servo to pan and the <up down> servo to tilt.
if it just stopped moving (and it worked before with the same settings) i would also check the batteries.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Unresponsive camera neilsonster Programming 9 17-02-2005 08:51
NEED HELP WITH CAMERA MOVEMENT nm4 Programming 3 10-02-2005 17:17
camera tracks but no movement from Robot Stillen Programming 4 04-02-2005 17:16
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
