Go to Post My friend Noah said he talked to someone that knew me from Chiefdelphi. That's just creepy. - Adam Y. [more]
View Poll Results: Where does your robot carry tetras?
Above the chassis 18 64.29%
In front of the chassis 7 25.00%
Behind the chassis 0 0%
Why would we want to carry tetras? 3 10.71%
Voters: 28. You may not vote on this poll
Unread 10-02-2005, 20:50
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Carrying Tetras
I have been thinking a lot about arm designs, and I have realised that most arm designs I have seen (including ours) do not allow the robot to carry the tetra above itself, it has to hold it out, which could make for some interesting tipping problems .
Where do you carry tetras?
Unread 10-02-2005, 20:55
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Carrying Tetras
We carry them between ~2 and 6 feet from our shoulder joint which is located near one of the upper corners of the robot.
Our first design was a 2 jointed arm much like many people are talking about, but before finalizing it, I ran some calculations I should have done much earlier to see how tippable we would be. The results were unacceptable to me, so we decided to drop the second joint in exchange for a slider carrying our tetra manipulators on our arm.
Team 1257
Unread 10-02-2005, 22:01
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Re: Carrying Tetras
We have a long "lance" that we use to spear the tetras, then we use a pneumatic to pull that lance up. It brings the Tetra closer in and allows us to cap higher.
Team Website
Unread 10-02-2005, 22:04
russell's Avatar
#1430 (WRONG)
Re: Carrying Tetras
Thats like what we are doing.
Unread 10-02-2005, 22:14
Rocketboy's Avatar
Rocketboy Rocketboy is offline
Programmer at work, Pilot by heart
AKA: Daniel Schoessler
FRC #1317 (Digital Fusion)
Rocketboy will become famous soon enough
Send a message via ICQ to Rocketboy Send a message via AIM to Rocketboy
Re: Carrying Tetras
We have a pneumatic on our arm with a 2 foot stroke. We can rotate it about 270 degrees around the lateral axis. When we hold it straight up with the cylinder in the extended position, our bot's about 12 feet tall. We need to do a tippability test.
-- Unofficial Google Advocate --
I soloed my
"Skyhawk" before I even soloed my car!
Unread 11-02-2005, 14:21
HPA_Robotics_13 HPA_Robotics_13 is offline
#833 Team Captain
AKA: Ben Honey
#0833 (HPA Robotics)
HPA_Robotics_13 will become famous soon enoughHPA_Robotics_13 will become famous soon enough
Send a message via AIM to HPA_Robotics_13 Send a message via MSN to HPA_Robotics_13
Re: Carrying Tetras
Our arm has both a shoulder and elbow joint. Our "end-effector" (which is our undisclosable top secret design) is such that we can leave the shoulder all the way down, drop the elbow, grab a tetra, and then lift the elbow back into a vertical position and one face of the tetra nests nicely at about 2 feet above the ground directly above the front end of our robot.
YMTC: Descoring Tetras??? Natchez You Make The Call 16 10-02-2005 13:00
Question: Missing Tetras in Human Loading Zone? tribotec_ca88 Rules/Strategy 7 15-01-2005 15:26
How to Stack Tetras in Inventor petek Inventor 0 13-01-2005 11:47
Just where are vision "bonus" tetras placed? David Brinza Rules/Strategy 17 10-01-2005 20:50
Manipulating tetras from the ground. Petey Rules/Strategy 4 08-01-2005 23:19
