Go to Post In 2012, we built our best machine ever. Some visitors to our pit were visibly disappointed to find that our machine was a pile of extruded aluminum and urethane belting, just cleverly arranged and programmed. - OZ_341 [more]
Unread 10-02-2005, 19:09
Fishdude404's Avatar
Fishdude404 Fishdude404 is offline
The fish king!! MUHAHAHAHAHAHAHAHAH
AKA: Andy Hsiao
None #1510 (Westview Robotics)
Team Role: Scout
Fishdude404 is an unknown quantity at this point
Send a message via AIM to Fishdude404 Send a message via MSN to Fishdude404 Send a message via Yahoo to Fishdude404
i need to find an anderson connector asap.
I can't seem to find some place to find an anderson connector. THe red connector thingy that goes onto the battery (connect thingy). i want the power cord with it too :-D. if you help me, thank you :-D
----My Setup----
-Tippmann A-5
-E-grip
-J&J 14" Ceramic Barrel
- Two wrongs don't make a right, but three lefts do
- If I agreed with you, we'd both be wrong
- Happiness is like peeing in your pants. Everyone can see it, but only you can feel it's warmth.
Unread 10-02-2005, 19:16
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: i need to find an anderson connector asap.
I don't think you can buy it with the wire already crimped in, but you can buy the contact/housing package here www.powerwerx.com (50 Amp SB Series) and solder in new wire (there is some in the kit).
Unread 10-02-2005, 21:07
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Don't just solder the wire into the connector, make sure you use a crimper meant for 6 gage lugs. I think actually there might be specific crimper's for those connectors. The reason why you don't want to just solder wires in is most solders are meant to melt at low temperatures and those temperatures can easily be reached with high current draws from motors like the Atwood/cim. If the solder melts theres a chance that it can bridge across the internal lugs and create a dead short.
-Michael Dessingue
Unread 10-02-2005, 22:03
Yes there is a special crimper for those and no it is not cheap. That is why we solder, but with a torch, not an iron. It works superbly if done right (right=not burning contact). Also, to clear some things up, current itself does not cause heat. Resistance does. I doubt the resistance in this large soldered connection would cause enough heat to even soften the solder. I think if you are melting solder joints, then you need not a crimping tool, but a more skilled individual behind the soldering tool. But perhaps Al will stumble along this thread and prove this one way or another.
Unread 11-02-2005, 01:50
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
The contacts powerwerx sells does not require a special crimper, it is not the same roll crimped connector that comes with the kit andersons. You can crimp it with the old kit crimper fine, although we do solder ours as well (we have a iron that can easially solder them). I would recommend against only soldering the connectors without crimping them first.
Unread 11-02-2005, 02:18
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Grainger if nearby usually has the 50 amp connector in stock. They do not sell one with cables connected to it but as mentioned above you could easily attach your own. I would more suggest a combination of both. First crimp then solder. The crimp will give a good physical contact and will hold the wire, the solder will give a good electrical contact.
-Mike
Unread 11-02-2005, 08:25
If you visit the Powerwerx site and search around you will find a variety of documents on the this family of connectors and you will see that there are two types of connctors (high detent and normal) and two types of crimp for each. Choose Wisely. The one style is easily crimped with standard crimpers.
Remember that a good soldered connection is one that is mechanically sound to begin with. A poorly made connection, even one that is soldered has the potential for high resistance (relatively speaking) which means heat. I have seen these contacts get hot enough to melt the plastic holding the contacts in place. This is a domino effect which can only increase the resistance and heat over a short time and yes it might get hot enough to melt solder. Most electronic solder alloys will melt at just over 400 degrees.
where can i find these?? jazzsaxman1988 Programming 3 05-02-2005 01:24
How to find the moment of an arm Matthew_H Technical Discussion 7 26-10-2004 12:20
3dmax - setting a display option that I can't find DanL 3D Animation and Competition 5 05-01-2003 12:42
Want to find out about other teams?? archiver 2001 0 24-06-2002 01:24
