Go to Post We were asked to help change a culture. If the solution was simple FIRST would have given more specific guidelines on how to do this. It is our job as teams to find unique and creative ways to help fulfill the request from FIRST. - tim-tim [more]
Unread 10-02-2005, 21:57
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Is it possible...
You could have 2 speeds by running the vents to a solenoid valve, and use it to switch between two flow controls.
Unread 11-02-2005, 16:35
BLAZE's Avatar
BLAZE BLAZE is offline
Team 96 Mascot
AKA: Andrew Brodecki
#0096 (Team Jester)
Team Role: Mascot
BLAZE is an unknown quantity at this point
Red face Re: Is it possible...
Yeah, someone was telling me that just today. We posted a question about it on the FIRST Q&A site, but it wasn't specific enough... my buddies want to know if anyone knows how to wire a solenoid valve? It figures it'd be complex... tooo much for brain!!!!! AHHHH!!! NEWay, thanks for the advice, it helps a lot. Do you know anybody going to the Arizona Regional? That's where my team will be heading... Never been off the east coast and it'd be nice to meet some "Westerners", pardon the expression... no offense.
Thanks again!
Don't jump in elevators!!!!!
Unread 04-04-2005, 22:02
dradius's Avatar
dradius dradius is offline
breakdancaz
AKA: ryan
FRC #0624 (CRyptonite)
dradius will become famous soon enough
Send a message via AIM to dradius Send a message via MSN to dradius
know im coming into this discussion late, but there ARE things you can do programming wize to change the speed at which it comes out and also how far it comes out.
1. changing how fast it comes out:
-tell the programmer to set the code so that when the soleniod is fired, make it relay on and off--the simplest solution to changing speed by controlling the amount of time that the solenoid allows air flow.
2. changing how far it comes out:
-hook up a second solenoid to the exhaust of the first one. in order for this to work, use something like a joystick interface, where you have control over positive, neutral, and negative current on the fly. dont have the exact code off the top of my head, but we did it this year and worked like a charm.
to control them remotely? hm. if you could change the frequency of open/close valve on the first solenoid by a dial and then the firing by a joystick, it could all be incorporated on a remote control of some sort.
just stopping in and giving my 2 cents, even though theyre late.
pessimist: glass is half empty
optimist: glass is half full
engineer: glass is twice the size it needs to be
--bringing green spikes and fishnets back in to style, baby--
