Go to Post Students, mentors, schools, corporations, teams, and communities - they are all critical to the success of FIRST. . - dlavery [more]
Unread 10-02-2005, 21:23
SpeakerSilenced SpeakerSilenced is offline
Programming/Electrical Team Member
#0219 (Team Impact)
SpeakerSilenced is an unknown quantity at this point
Send a message via AIM to SpeakerSilenced
Radios dont like each other?
For some reason our radios dont seem to like each other, we can hook up the and run the robot well with the tether, but our radio has stopped functioning for no reason, we've done the test procedure and we even tried them with the default code and updated mastercode. The OI radio keeps transmitting, while the Robot's radio just stand bys.
Any ideas?
"I want to put a ding in the universe" - Steve Jobs
Unread 10-02-2005, 21:30
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
Re: Radios dont like each other?
I really hate it when people say somthing so easy when I have a question, and i feel liek (I ovciosly checked that)
but here I go anyways....
Are the team dipswitches on the OI and RC the same?
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 10-02-2005, 21:40
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
I believe this year the OI automatically is set via tether when the RC dipswitches are set.
A problem I've seen happen quite often... sometimes the room your in actually acts like a sponge with the radio signals. Have you tried placing the 2 radios very close to each other and/or going to another room? If that doesn't work, I'd think it's most likely that one or both of the serial cables connected to the radio(s) is bad, which happens from time to time... try using another 9-pin serial cable.
Unread 10-02-2005, 21:50
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
Hey guys, im on the team with scilenced. One day we were driving around using the modems, then we turned it off to work on a speed controller. While they were doing that, others (myself and a few) set the team #. When we turned the bot back on, nothing.
Just wanted to let you guys know what happened before, during and after they ceased functions
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
Unread 10-02-2005, 22:00
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Oh, you need to plug them together with the tether when you set the team number. I dont know if you need to set it back to zero now and reset the number or if you can just plug them together and it will work, but what I would do is hook them together with the tether, give them a few seconds to get connected, make sure the link is working, then uplug the tether and try the radio again. If it still doesnt work then set the team number back to zero, plug in the tether, then reset the team number.
Unread 10-02-2005, 22:07
M. Hicken's Avatar
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
bingo, thanks. Gus, let me know if you cna do that anytime tomorrow, if not, ill come in during block A.
Unread 10-02-2005, 23:11
#0219 (Team Impact)
I'm going to be working on it Block E cause we got that new serial thing... I might be able to miss gym for the bot.
Who the hell needs gym anyways
Thanks for the help
Radios not working... E Jones 234 Control System 3 21-01-2005 21:58
Radios not getting signals BrendaB Control System 3 24-01-2004 22:50
What subtitutes controllers, radios, Victors and Spikes? Digo Technical Discussion 6 15-05-2002 16:04
problems with receiving signals between radios (need help0 chrisw Technical Discussion 4 11-01-2002 10:35
Boosting signal on radios? Dave Hurt Technical Discussion 2 14-11-2001 16:07
