Go to Post theyre not planning on blowing up the comet... just running straight into it and seeing what happens. :D - Winged Wonder [more]
Unread 10-02-2005, 23:01
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
If statement in .h file or Indirect addressing? Kevin NAV code...
Ok...so I am not sure how to explain what I need but I know what I want to do.
I am helping our team program this year and really this is the first time I've dabble in C code. I normally program PLCs (programmable logic controllers)...anyway...
I noticed that Kevins nav code uses a commands.h file which is a structured something to send commands in a list format to the robot.c file. Very slick and easy. We've made our own functions and commands for our automous mode.
What I'd like to do is alter this with some inputs to create multi automous modes. We have all the inputs selections working but not sure what would be the best approach in C code to do what we need.
I want to do something like this:
if (input = 1)
    struct commands command_list[] = {
    /*   Command              parm 1     parm 2   parm 3   */
    {CMD_WAIT,                 1000,        0,      0},
    {CMD_DRIVE,                1500,        0,      0},
    {CMD_WAIT,                 4000,        0,      0},
Of course that's not exactly legal in C code....
So if I was doing this in a PLC, I might use what is called indirect addressing, or assigning a varaible to a pointer.
Like:
struct commands command_list*myvarible*[] =
so if myvarible is equal to 1 then run the commands in list #1. If myvarible is equal to 2 then run the commands in list #2.
Is there such a thing like this in C Code?
I hope that makes sense...
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 10-02-2005, 23:12
Workaphobia Workaphobia is offline
AKA: Jon
FRC #1546 (Chaos Inc.)
Workaphobia will become famous soon enough
Re: If statement in .h file or Indirect addressing? Kevin NAV code...
You want the struct you use to be one of a predefined set, that is selected at the beginning of runtime? You could try a big switch() statement that would contain assignment statements.
struct commands mycommand;
switch(input)
  case 1:
    mycommand = {...};
    break;
  case 2:
    ..... repeat
Not sure if I have the syntax right - it's late, and I haven't used structs in a while.
I wouldn't use a pointer to an array element because you'd be allocating space for structs that would not be used - you wouldn't switch modes after starting the process.
Unread 10-02-2005, 23:25
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
I think what you're looking for is to assign a pointer to the correct array of autonomous commands based on some input at runtime.
Example:
.h file:
struct commands command_list_drive_straight[] = {
struct commands command_list_grab_tetra[] = {
In .c:
struct commands* cmd_list = NULL;
if(input == 1)
    cmd_list = command_list_drive_straight;
else if(input == 2)
    cmd_list = command_list_grab_tetra;
else
    /* Don't forget the else, else you'll be accessing a null pointer... :( */
etc...
This actually doesn't matter - the compiler has to store the values that your code will use to initialize the array somewhere inside the program anyway, so it's essentially the same. Actually, using globals with assigned default values (especially if you make them const) is more efficient because then they can be stored directly in Flash and don't need to consume any RAM.
Unread 11-02-2005, 00:20
Controls Engineer
AKA: chakorules
Yeah, yeah...great fixer-her-upper. What we got Dave is some thumbwheels from digikey connected to the four inputs on a joyport. Using BCD (0-9), we can run up to 99 different automodes with eight inputs on two ports. I'll give your example a shot and see what we come up with...PS thanks alot for sharing your thoughts.
Next on the list is shaving more program FAT. Every time we turn around we are at our 32K limit...yuck...We aren't ready to get rid of the printf statements, we need those to debug but if it keeps it up, we are going to have to dump some printf to get more code packed in...
Favorite CD quote:
Unread 11-02-2005, 10:24
I found it much easier to use primitives rather than printf. printf takes 4K while a simple set of primitives takes 40 bytes. The ones we use aren't even the real way I'd normally implement such a thing, but it made a good "hello world" type intro to programming project for the freshmen.
Unread 12-02-2005, 00:37
Controls Engineer
AKA: chakorules
Hey DAVE...
We just wanted to tell you this worked like a champ...BUT..holey-moley...does it eat up some program space... With the default struct command, we had 23K of program space left to mess with. Then we did your suggestions, and we duplicated the struct with three sets to represent three different automous modes, after we done that we now have 28K of complied program...whew... That was a big hit in our software... Anyway though, it worked like a champ, exactly what we need in conjuction with our thumbwheel 0-9 BCD (binary coded decemical) input wheels.
Favorite CD quote:
Unread 14-02-2005, 10:34
Software Engineer
Rookie Year: 1995
How many commands do you have in each of your autonomous programs? Each "command" inside the commands array looks like it takes up 10 bytes... You'd have to have some pretty big autonomous programs to add 5K. You are just using a pointer to the correct struct, right (versus creating a new struct and assigning the values from the struct in commands.h to it)?
Unread 14-02-2005, 11:27
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
if (input = 1)
Like:
It does....another approach (which might save some memory space), is based on your thumbwheel positions, call a function which puts the dsitred command list into the structure. That way you'll just have one structure, not multiple copies.
Jon Mittelman
Unread 14-02-2005, 15:14
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
I was pretty excited about the scripting idea. I modified the system to allow multiple "scripts" in the one array. I even allowed scripts to call other scripts, subroutine-like. This took a lot of time to get working, but I figured I we would write a short 4-6 command script for each of a dozen different autonomous programmes, and life would be grand.
But by the time I got up to about 7 scripts, the linker said it couldn't fit the array. I even tried breaking the array up into multiple arrays, but the linker was still upset. I posted a question about modifying the linker script, but, so far, no responses.
Realizing that there is far less RAM for data like script arrays than there is memory for program storage, I threw out my wonderful scripting system and I plan to implement a nested-state machine system. There's still, what? a week left?
-Norm
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 14-02-2005, 15:27
You can put data like script arrays in the program storage area. Just declare it as a rom const.
Unread 14-02-2005, 15:46
Software Engineer
Rookie Year: 1995
You'd be better off declaring all the arrays as rom const as Alan described, because if you have a function copy the data into the struct then all that data still has to reside in Flash AND then you end up using a bunch of RAM for the RAM copy. You may as well just use it out of Flash directly. Plus you'll waste a bunch of CPU cycles doing the copying . We're not using the script language but from what I understand the array does not get changed at run-time so it's a good candidate for making rom const. Unfortunately that doesn't help with Chris' other problem of filling up the 32K of Flash.
Something that might be worth considering is using the EEPROM to store your autonomous programs to get them out of Flash - you'll have to use the EEPROM code that someone posted on here last year though and it would generally be painful, but it would free up some space.
Unread 14-02-2005, 23:39
Controls Engineer
AKA: chakorules
This is some really good stuff guys. Thanks for posting information and sharing your ideas. I'll have to try this when I get back, I am out of town on business away from the team right, bad timing to have to leave on business for the "real" job on the last week of the build season...
Anyway, we have done pretty much what Dave has suggested:
if(thumbwheel == 0)
    cmd_list = command_list_00;
else if(thumbwheel == 11)
    cmd_list = command_list_11;
else if(thumbwheel == 21)
    cmd_list = command_list_21;
else if(thumbwheel == 31)
else
    cmd_list = NULL;
Then our command list looks something like this...I won't post them all, but you can see how the flow goes.
//do nothing but sit here and look pretty
struct commands command_list_00[] = {
{NULL,                         0,        0,      0}
//ok robot starting on the left or right side MODE 11
struct commands command_list_11[] = {
{CMD_DRIVE_UNTIL,         	  1400,        180,      0}, //drive time with PWM value
{CMD_SELECT_GREEN,       	     0,        0,      0}, //change color to green, no values needed.
{CMD_WAIT_UNTIL_VISLOCK_GREEN,	 0,        0,      0}, //lock on green, not values needed.
{CMD_WAIT,                 		50,        0,      0}, //YOU MUST DELAY HERE! (wait for in milli-seconds)
{CMD_DRIVE_ALIGN_COLOR,      	149,        5,      20}, //line up with tetra, PWM value and SCALER number here
{CMD_WAIT,               		50,        0,      0}, //wait in milli-seconds.
{CMD_DRIVE_UNTIL_CLOSE,         160,       200,      0}, //drive straight PWM value, then how close in second value is size bigger means closer.
{CMD_DRIVE_UNTIL,         	   600,        165,      0}, //drive time with PWM value
{CMD_SELECT_YELLOW,       	     0,        0,      0}, //change color to yellow, no values needed.
{CMD_WAIT_UNTIL_VISLOCK_YELLOW,	 0,        0,      0}, //lock on yellow, not values needed.
{CMD_NO_VISION,           	    0,        0,      0}, //disable vision system no values needed
{NULL,                    	    0,        0,      0} //turn off auto mode no values needed
Favorite CD quote:
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
File Sharing and Revision Tracking Madison FIRST-related Organizations 14 04-06-2003 18:01
