Go to Post I dont think it matters too much what you do, as long as you do something that lets you apply what you're learning in class. - MrForbes [more]
Unread 11-02-2005, 02:01
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Re: Electronics visible?
They also wanted the "Robot Reset" button accessable when they inspected us at Sac.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 11-02-2005, 02:29
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Fortunately, if that's a problem, there are header pins on the RC to which you can connect external switches to replace both the Program and Reset switches.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 11-02-2005, 03:17
FRC #0973 (GRR)
Electrically thats possible .. if the inspectors allow it is another story.
2011: ???
Unread 11-02-2005, 08:16
That's why they are part of the RC. Please make electronics visible, it makes an inspection much easier and it willhelp you when a problem arises. Don't forget a potential finals alliance partner will want to know you can make repairs quickly and diagnose problems should they arise.
Unread 11-02-2005, 09:34
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
<R63> A remote reset and remote programming switch may be wired to the Robot Controller’s RESET/PROG header. Any switch may be used. See the Robot Controller Reference Guide for wiring information.
There is no requirement for access to the RESET button this year. But it is still a good idea
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 11-02-2005, 11:52
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Please please please take this to heart. It only takes one "we have an elimination match in FIVE MINUTES!!!" with one bad inaccessible wire/pwm cable/fuse/radio/whatever to ruin an entire year...
No one will tell you that you need to spend all your time laying out your robot components, but do make sure you at least try to make things accessible.
-SlimBoJones...
Unread 14-02-2005, 23:54
DarkWombat DarkWombat is offline
#0840 (Aragon Robotics Team)
Team Role: Electrical
DarkWombat is an unknown quantity at this point
Hmm...well our team planned to get an aluminum hood that would cover the electronics and protect them during operation. However, the hood will be hinged on the side so that it can be easily opened up to access the electronics. So does this mean that we'll have to cut a slot open in the hood so that the LED's will be visible while we're competing? I'm getting mixed answers from this thread, I understand that we'll have to have the electronics ACCESSABLE, but do we also need to have the LED's visible so that they can be seen from a distance while the robot is in use (competing on the playing field)? Because I don't think that'd matter much, since if the LED's WERE visible you wouldn't be able to discern from twenty feet which LED was correpsonding a certain problem anyways.
So I guess the question is: can we use a protective shielding/hood to protect the electronics during operation, but which can also be easily removed to access the electronics componenets for inspection and while in the pit area?
Unread 15-02-2005, 07:44
ttedrow's Avatar
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
The answer from this Inspector is: as minimum the LEDs on the RC must be visible without opening/removing anything.
This is due to the time sensitive nature to the competition. The IFI rep checks each robot before each match.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
Yes, Chute Door!!!
Unread 15-02-2005, 07:56
You can do whatever you think is best but...If an IFI rep or another smart individual can't see the panel when you are having a problem, they won't be able to help. It is wise to cover the RC but when things start acting up, you want to be able to get some feedback and see that all the PWM connectors and sensor are still connected. When you are 30 seconds from the start of a match and are on the field with your alliance waiting for you, do you want to be removing a big metal cover?
As an inspector, I will agree with Mr. Tedrow, we need to see to help you.
Unread 16-02-2005, 09:18
Adam Krajewski's Avatar
Adam Krajewski Adam Krajewski is offline
AKA: Jewski
None #0857 (Superior Roboworks) / Team #0068 (Truck Town Thunder)
Adam Krajewski is on a distinguished road
Protecting the electronics is a smart idea. However, you are better off using polycarbonate instead of aluminum.
"My favorite programming language is solder."
- R A Pease
Unread 16-02-2005, 09:44
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
lexan is perfect, strong and see through
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 16-02-2005, 12:06
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Unless you're using transparent aluminum. Oh Wait that hasn't been invented yet
Christopher H Husmann, PE
"Who is John Galt?"
Unread 16-02-2005, 13:08
http://physicsweb.org/articles/news/8/8/9
Unread 16-02-2005, 23:50
Thanks for the responses. We're probably going to just mill a rectangular hole in the center of the hood and screw on lexan to cover it. And that aluminum article, even though it's around 6 monhts old, is pretty interesting. It's only a matter of time....
Think....transparent titanium?
Programming and Electronics — Getting Started Sidney San Martín Technical Discussion 7 12-01-2005 15:25
Books on electronics relating to robotics patrickrd Technical Discussion 1 15-05-2004 21:28
Covering Electronics shyra1353 Rules/Strategy 6 24-02-2004 22:23
Professional electronics board assembly [annotated collector's edition] Geoff General Forum 7 17-02-2004 21:57
Question about buying electronics _GP_ General Forum 5 01-02-2004 12:43
