Go to Post there should be a continuous cascade of knowledge spilling over to the less experienced team members and and continuous upward flow of members gaining experience. - ebarker [more]
Unread 10-02-2005, 19:25
crazykid234's Avatar
crazykid234 crazykid234 is offline
Techincal assist
AKA: Brian Clegg
FRC #1646 (Precision Guessworks), Alumni FRC #234 (Cyber Blue)
crazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to behold
Accelerometer Connection Help
What do you connect the accelerometer's lead wires to? A PWM? I know that the accelerometer has to be wired to analog input 1, but what do you use to connect it there? Our team has always used a PWM cable when connecting anything to the robot controller. Any ideas/suggestions? All help is greatly appreciated.
Don't see the world as it is and ask why; see the world as it could be and ask, why not? - unknown author
Unread 11-02-2005, 02:19
Team 668 Team 668 is offline
#0668 (The Apes of Wrath)
Team 668 is an unknown quantity at this point
Re: Accelerometer Connection Help
yeah, we just took an old PWM cable and soldered the cables from the accelerometer to the male end of the cable...
Unread 11-02-2005, 08:23
Erics626's Avatar
Erics626 Erics626 is offline
Cool, Calm, Collected
None #1018 (Robodevils)
Team Role: Electrical
Erics626 is a jewel in the roughErics626 is a jewel in the roughErics626 is a jewel in the rough
Send a message via AIM to Erics626
I took the the male end of the PWM cable off and just soldered the wires to the accelerometer. Be careful though, the ground and supply are opposite of what you think they may be. Ground is red and supply is black.
Championship Finalist - 2006 Buckeye Regional (Thanks 461 and 141!)
Fourth Year FIRST Member
Third Year Electrical Team Leader
First Year BEST and FIRST Robotics Team Co-Leader
Second Place - Robotics Competition, 2005 Bearcat BEST
Second Place - BEST Competition, 2005 Bearcat BEST
Most Photogenic - 2005 Bearcat BEST
Most Robust - 2005 Bearcat BEST
Fourth Place - Robotics Competion, 2005 Nationals(South's BEST)
"Get your philosophy from a bumber sticker."-Billie Joe Armstrong
URGENT! We need help with the accelerometer lkdjm Electrical 5 11-02-2005 16:42
Accelerometer: Analog or Digital? psquared Programming 2 10-02-2005 16:38
Accelerometer Wiring/Input DAN THE MAN Control System 1 06-02-2005 20:02
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
Example accelerometer code released. Kevin Watson Programming 0 20-01-2005 03:45
