Go to Post FIRST is not about robots or which roller coaster we get to ride... it is about people. - Andy Baker [more]
Unread 11-02-2005, 09:44
Moloch's Avatar
Moloch Moloch is offline
Moloch can only hope to improve
Where to place Hall Effect Sensors.
I know there is already a thread on this topic, but I need a more clear answer. Where exactly is the best place to put the Hall effect sensors? And what is the best way to mount them?
Unread 11-02-2005, 10:14
zdeswarte's Avatar
zdeswarte zdeswarte is offline
AKA: Zack
None #1240 (LHS Robotics)
Team Role: Electrical
zdeswarte is on a distinguished road
Send a message via MSN to zdeswarte
Re: Hall Sensors...
All I know is that they need to be pretty close to the gears without touching them. They also need to be near the gear teeth so that the sensor senses the variations between tooth and valley. My team abandoned using those because we don't know enough about them but thats what we figured out. Its probably going to be more of an off season project than anything.
Unread 11-02-2005, 10:15
Moloch's Avatar
Re: Hall Sensors...
Do they have to be close the the teeth on the wheels or in the transmission?
Unread 11-02-2005, 10:19
zdeswarte's Avatar
AKA: Zack
Re: Hall Sensors...
I would do it close to the wheels- its closer to the actual output that you'll be looking for. The bigger the teeth and valleys the better results you'll get, and I would bet that the wheel sprockets are the best place to put them for this reason. Either way works though, it just depends on your bot.
Unread 11-02-2005, 10:28
Moloch's Avatar
Re: Hall Sensors...
Thinking about putting on extra wheels for the soul purpose of counting teeth. This will prevent skid and spinning. Not sure how accurate or phesable this will be though.
Unread 11-02-2005, 10:49
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Re: Hall Sensors...
not a bad idea.
the hall effect sensors need to sit really really close to the gears, about 3 mm, right in front of the point where the teeth change from peak to valley.
a good indication would be to move them closer by hand, until you can feel the magnet inside them pulling the you towards the gear.
in order to position them accurately, i would suggest that you use an oscilloscope, that way you have a visual and real-time reference , so you can decide exactly where to put them.
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 11-02-2005, 13:07
Mark Pierce Mark Pierce is offline
FRC #0085 (B. O. B.)
Mark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant future
Re: Hall Sensors...
This is a good idea, but the measuring wheels need to be sturdy enough to handle side loading when the robot turns and such. My experience when we attempted this was the weight budget and design time the mechanical guys left us with was not enough to make sturdy wheels.
Unread 11-02-2005, 13:12
Moloch's Avatar
Re: Hall Sensors...
What about the wheels slipping? How do we count that into effect? Any advice is welcomed openly.
Unread 11-02-2005, 15:00
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Re: Hall Sensors...
wheel "slippage" can only occur on a wheel which offeres some resistance to turning (i.e. a powered wheel or one with a brake turned on et cetera), so if you used a wheel that was not powered to count revolutions, that wheel would not slip therefor no problem.....
also, you were given an acceleromneter, so you could tell if the acceleration measured by the hall effect sensors (you would need to calculate this) is different than the one you get from the accelerometer, you would know you are slipping.....
calculating the difference between the accelerometer and the hall effect sensors would be difficult, since they do not automaticly have the same units..... though now that i think about it.... you could just use psudo units....
-Leav
-Paraphrasing JFK
Unread 11-02-2005, 15:11
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
Re: Where to place Hall Effect Sensors.
One thing that also should be considered is WHICH gear you place the hall effect on. Placing them on a wheel sprocket will give you a lower resolution than if you place it on a gear higher up in your gearbox. This is because your wheel sprocket spins much slower than a gear in your gearbox. 1114 did some experimenting with this in the preseason and found we needed to place it on the first stage of our(AndyMark) gearbox to get the resolution required.
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
Unread 11-02-2005, 16:47
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
As a note for rookie programmers, though, more resolution inevitably means more counts per second. This means more interrupts per second, which can horrendously slow down your main loop if you start getting too many interrupts too quickly. So you need to strike a balance, as in most engineering problems.
Hall Effect Sensor Example Code JJMax7 Programming 6 16-02-2005 02:38
Hall Effect Sensors GAT-X105 STRIKE Programming 2 15-02-2005 23:25
Hall Effect Sensor. Nixterrimus Electrical 77 29-01-2005 10:48
Hall Effect Source LaughingJack Programming 3 26-01-2005 05:28
Code violation using Hall effect sensor pickle Programming 9 19-01-2005 00:10
