Go to Post Multitasking is a myth. - DonRotolo [more]
Unread 08-02-2005, 14:35
lkdjm's Avatar
lkdjm lkdjm is offline
AKA: David Mazza
FRC #0564 (Digital Impact)
lkdjm will become famous soon enough
Send a message via AIM to lkdjm Send a message via Yahoo to lkdjm
Question URGENT! We need help with the accelerometer
WE NEED HELP!
We are using autonomous mode for the first time this year and with only 12 days till the ship date, we havn't been able to figure out the following things:
1. Where (on the robot) the accelerometer is installed. Note: we have the TI
2. How and where to attach the wire to the rc controller (computer on the robot)
3. What the magnets are, how the work, and how they are installed.
4. How to program autonomous mode for the accelerometer. we saw the white paper on simple scripting and read through it SEVERAL TIMES. We do not now how to implement it into kevin's nav code. Is there any other way to use the accelerometer than that?
Any help is GREATLY APPRECIATED
THANK YOU in advance.
Unread 09-02-2005, 18:09
Ammonium's Avatar
Ammonium Ammonium is offline
AKA: Zack
FRC #0145 (T-Rx)
Ammonium is an unknown quantity at this point
Send a message via AIM to Ammonium
Re: URGENT! We need help with the accelerometer
FIRST released a pdf you probably already have, but if you don't, I hope it helps
http://www2.usfirst.org/2005comp/Spe...elerometer.pdf
And Kevin knows load about it...again you probably have it but if you dont...
http://www.chiefdelphi.com/forums/showthread.php?t=33108&highlight=accelerometer+wir e+color
-Zack
"What an artist the world loses in me"
Unread 11-02-2005, 15:19
lkdjm's Avatar
AKA: David Mazza
Yeah I have both of those documents, but thanks anyway!
Unread 11-02-2005, 15:40
Originally Posted by lkdjm
WE NEED HELP!
1) You can mount the accelerometer anywhere on your bot. Follow the mounting direction section in the TI pdf.
2) Connect the wires from the accelerometer just as the RC says. Connect black to BLK/GN, red to RED/+5V, amd white to WHT/SIG.
3) Im guessing by magnets you mean the tooth counters that came in the same box as the acceleromter. These are different sensors and have nothing to do with the accelerometer. You can use them to count passing gear teeth in a gearbox.
4) There is no right or wrong way to program autonomous mode. Sensors dont need to be used, but they can help. First, figure out what you want to do. See if it can be made more accurate with sensing abilities, and then choose the correct sensors for the job. But, its kinda late for that, theres only a week and a half left .
If you are wondering what these sensors are used for, they can be used for pitch or roll rate sensing, or sensing amounts of linear acceleration. That acceleration can then be converted to speed or with the right math, distance travelled.
Unread 11-02-2005, 15:54
Not for the accelerometer, as the wiring harness provided has +5 and GND reversed. For the accelerometer ONLY, connect red to black and black to red. This is covered in Kevin's code, and many threads here. It's also obvious if you compare the wiring harness to the drawing on the spec sheet.
Unread 11-02-2005, 16:42
Good catch, Joe. We're not using the accelerometer so I never really took note of that.
Accelerometer Wiring/Input DAN THE MAN Control System 1 06-02-2005 20:02
Some things i'm trying to understand on Kevin's Accelerometer Code Squall Programming 2 03-02-2005 12:01
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
Example accelerometer code released. Kevin Watson Programming 0 20-01-2005 03:45
URGENT!!! In Need of Drill Motors LBK Rules General Forum 0 21-02-2004 16:50
