Go to Post The best revenge is living well. - gblake [more]
Unread 11-02-2005, 15:43
willie837's Avatar
willie837 willie837 is offline
#0837 (Webbinators)
willie837 is an unknown quantity at this point
Send a message via AIM to willie837
Exclamation Need Serious Gimungous Huge Major Seriously Awesome Help
I need a button code for operating our arm on our robot. Any code would be nice. Thank you.
P.S.- We have a single joystick code, if that matters at all.
Freshman
Please, I need your help with programming. It is my first year with Robotics and I have been chosen as programmer. If possible can anyone IM or PM me with some codings to help with the prgramming? I need especially a code to change our robot's control to two jostick tank drive from one jostick drive. I also need autonomous help. Thank you so much.
"Don't Die Worrying..." Alicia Molik
Unread 11-02-2005, 16:05
Re: Need Serious Gimungous Huge Major Seriously Awesome Help
What moves your arm? A motor? Pneumatics? A herd of servos in parallel? The code you need has to control the device you use.
What button are you using? What do you want to have happen when you press the button? The code you want has to implement that.
After you give some real specifications for what you want, we can start giving useful suggestions on how to meet them.
Unread 11-02-2005, 16:19
willie837's Avatar
#0837 (Webbinators)
Alrgiht, we have a pneumatic arm with three different cylinders, one for lifting, and two for extension. We need code to operate these three cylinders with one joystick, so we can have another for driving. We need three different buttons to operate each cylinder, the first press to activate the cylinder out, and the second press of the same button to retract it.
Freshman
Unread 11-02-2005, 16:26
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Check out this thread.
What you're looking for is a way to toggle a relay output with a button tap. There were several solutions mentioned.
Unread 11-02-2005, 16:34
willie837's Avatar
#0837 (Webbinators)
The code we saw is not working. Where in the Default Code do we put it? Or what is another code?
Freshman
Unread 11-02-2005, 16:38
...pneumatic arm with three different cylinders...one joystick...three different buttons to operate each cylinder, the first press to activate the cylinder out, and the second press of the same button to retract it.
Fortunately, the white joysticks have lots of buttons! Assuming the joystick is on Port 4 of the OI, the trigger is p4_sw_trig, the thumb button is p4_sw_top, the left hand button on top is p4_sw_aux1, and the right hand button on top is p4_sw_aux2. Pick which three you want to use. I'll show you how to use the trigger for what you want, assuming you're using a double solenoid connected to a Spike on Relay 1, and you can go from there.
In the Default_Routine() function in user_routines.c, use this code:
static char last_trig = 0; // this is what the switch state was last time
static char cylinder_state = 0; // this is what we last told the cylinder
if (last_trig == 0 && p4_sw_trig == 1) // the switch was just now pressed
    if (cylinder_state == 0) // the cylinder was retracted, need to extend
        cylinder_state = 1; // remember that we're extending it
        relay1_fwd = 1; // do whatever it takes to activate the solenoid
        relay1_rev = 0;
    else // the cylinder was extended, need to retract
        cylinder_state = 0; // remember that we're retracting it
        relay1_fwd = 0; // do whatever it takes to reverse the solenoid
        relay1_rev = 1;
last_trig = p4_sw_trig;
Unread 14-02-2005, 15:36
willie837's Avatar
#0837 (Webbinators)
Thanks. I think we are going to use the trigger, left hand button on the top, and thumb button.
Freshman
