Thread Tools |
Rating:
Display Modes |
Re: **FIRST EMAIL**/Fisher-Price Motor Information
Thanks Paul.
I have one question. Everyone says that the FPs will inevitable fail. Besides JVN's beating, has anyone actually had this year's motor fail yet? If so, can we hear about the situation it was used in and the failure that occurred? |
What has been discussed is that if you stall an FP at 12V it will fail very quickly. Stalling an FP at 6V should be OK for quite a while. Operation at high voltage and high torque (low speed) is problematic but you have an increased chance of failure the higher in voltage/torque you go. At issue is that these are self cooling motors (you can see the fan in the end). If you put enough torque to slow the fan (motor) above 6V, you are at risk. Regards, |
IMHO, how to address the design issue of a 6V FP is still relevant. |
Last year First included a current sensor as part of the kit. If any teams still have the current sensor, they could use it to monitor and control the current to this years Fisher price motor and gear box. It could be used as a fixed point limit or with a little more programing starting curves could be implemented.
[edit] Not really illegal, but you would have to cost account a custom PCB... Not trivial... [/edit] Last edited by Mike Betts : 11-02-2005 at 22:23. |
#7
If teams have the parts, perfboard and kludge it. There are also 1 chip solutions from digikey.
#8
Another option for teams electing to run the 6 volt motor is to limit the peak voltage going into the PWM to avoid over heating the motor. I tested running a Blue Victor using a 6 volt supply and it appeared to run well. I am not an EE, so I can't say if this is safe for the PWM - I would continue to run the PWM fan on a separate 12v circuit. I also am not sure if this violates some other safety/construction rule. So I'd appreciate it if an EE and someone from the rules committee would chime in. I checked on Digikey, and there are many solid state voltage regulators at 5, 6, 7 volts and up to 20 amps. There is a cheap hobbiest trick that uses 2 diodes to float the center tap of a 5 volt regulator. This should result in a 6.2 volt output on the regulated supply.
Even the 12v FP motors and transmissions tend to heat up in competition - so I would consider using a fan to cool them. A simple trick is to position the PWM near the motor so that air is always blowing over the motor. |
#10
Alan,
Just limit the PWM signal to a 50% duty cycle (verify with a good analog meter like a Simpson) and you do the same thing (and stay within the rules to boot). |
#11
| Use of the fisher price motor ALONE | Some Guy | Motors | 6 | 03-02-2005 08:55 |
| Need Fisher Price Motors | kevinw | Motors | 1 | 13-02-2003 18:44 |
| Multiple Fisher Price Motors? | authgeek1218 | Motors | 5 | 10-01-2003 10:48 |
| Fisher Price Motors for Drill Motors | archiver | 2001 | 0 | 24-06-2002 00:22 |
| New Fisher Price Motor - IMPORTANT | Paul Copioli | Motors | 6 | 08-02-2002 13:35 |
