Go to Post Think Tolerant. - petek [more]
Go Back   Chief Delphi > FIRST > General Forum > FIRST E-Mail Blast Archive
  #31   Spotlight this post!
Unread 11-02-2005, 18:26
Electrical Engineer
Rookie Year: 1995
Re: **FIRST EMAIL**/Fisher-Price Motor Information
Originally Posted by sanddrag
Thanks Paul.
I have one question. Everyone says that the FPs will inevitable fail. Besides JVN's beating, has anyone actually had this year's motor fail yet? If so, can we hear about the situation it was used in and the failure that occurred?
If designed in correctly, the FPs should not fail.
What has been discussed is that if you stall an FP at 12V it will fail very quickly. Stalling an FP at 6V should be OK for quite a while. Operation at high voltage and high torque (low speed) is problematic but you have an increased chance of failure the higher in voltage/torque you go.
At issue is that these are self cooling motors (you can see the fan in the end). If you put enough torque to slow the fan (motor) above 6V, you are at risk.
Regards,
Mike Betts
As easy as 355/113...
  #32   Spotlight this post!
Unread 11-02-2005, 20:04
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Everyone should read this before continuing discussion here.
Zan Hecht
  #33   Spotlight this post!
Unread 11-02-2005, 21:08
Electrical Engineer
Rookie Year: 1995
Zan,
IMHO, how to address the design issue of a 6V FP is still relevant.
Mike Betts
  #34   Spotlight this post!
Unread 11-02-2005, 21:46
Gdeaver Gdeaver is offline
FRC #1640
Last year First included a current sensor as part of the kit. If any teams still have the current sensor, they could use it to monitor and control the current to this years Fisher price motor and gear box. It could be used as a fixed point limit or with a little more programing starting curves could be implemented.
  #35   Spotlight this post!
Unread 11-02-2005, 21:57
jrocket567 jrocket567 is offline
FRC #0617
jrocket567 will become famous soon enoughjrocket567 will become famous soon enough
hmmm... back to the drawing board, and digging around in previous year's junk.. i think were gonna attempt to put in the old motors.. what's everyone else planning on doing this late in the game??
  #36   Spotlight this post!
Unread 11-02-2005, 22:20
Electrical Engineer
Rookie Year: 1995
While the individual components would qualify, I'm not sure that last year's printed circuit board is available to all teams... If not, it would be illegal...
[edit] Not really illegal, but you would have to cost account a custom PCB... Not trivial... [/edit]
Mike Betts
  #37   Spotlight this post!
Unread 12-02-2005, 09:41
FRC #1640
If teams have the parts, perfboard and kludge it. There are also 1 chip solutions from digikey.
  #38   Spotlight this post!
Unread 12-02-2005, 11:06
This post may be helpfull for people trying to account for the cost: http://www.chiefdelphi.com/forums/sh...7&postcount=42
  #39   Spotlight this post!
Unread 12-02-2005, 19:59
Dr.Bot
Posts: n/a
Another option for teams electing to run the 6 volt motor is to limit the peak voltage going into the PWM to avoid over heating the motor. I tested running a Blue Victor using a 6 volt supply and it appeared to run well. I am not an EE, so I can't say if this is safe for the PWM - I would continue to run the PWM fan on a separate 12v circuit. I also am not sure if this violates some other safety/construction rule. So I'd appreciate it if an EE and someone from the rules committee would chime in. I checked on Digikey, and there are many solid state voltage regulators at 5, 6, 7 volts and up to 20 amps. There is a cheap hobbiest trick that uses 2 diodes to float the center tap of a 5 volt regulator. This should result in a 6.2 volt output on the regulated supply.
Even the 12v FP motors and transmissions tend to heat up in competition - so I would consider using a fan to cool them. A simple trick is to position the PWM near the motor so that air is always blowing over the motor.
  #40   Spotlight this post!
Unread 12-02-2005, 20:24
Electrical Engineer
Rookie Year: 1995
Alan,
Just limit the PWM signal to a 50% duty cycle (verify with a good analog meter like a Simpson) and you do the same thing (and stay within the rules to boot).
Mike Betts
Use of the fisher price motor ALONE Some Guy Motors 6 03-02-2005 08:55
Need Fisher Price Motors kevinw Motors 1 13-02-2003 18:44
Multiple Fisher Price Motors? authgeek1218 Motors 5 10-01-2003 10:48
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
New Fisher Price Motor - IMPORTANT Paul Copioli Motors 6 08-02-2002 13:35
