Go to Post You can't reprogram physics. - Kevin Sevcik [more]
Unread 11-02-2005, 22:58
psquared psquared is offline
psquared is an unknown quantity at this point
Accelerometer Timer Question
I am looking over the accelerometer code tonight, this way when i go in to program tomorrow, I'll be able to get started right away. I was looking over Kevin Watson's accelerometer code and I think I am understanding it, but I had a few questions.
The void Timer_2_Int_Handler is what contains all of the code to actually calculate the current acceleration of the robot, and update that acceleration. (I hope I am right here, otherwise i think im gonna be in trouble ) The void information says that it is called from user_routines_fast.c/InterruptHandlerLow(). This is where I am confused. Since we initialize the accelerometer with Initialize_Timer_2 which says it starts the timer, do I have to call this void (Timer_2_Int_Handler) in my user_routines.c or will it be automatically called. The reason why I am curious is b/c in the _fast.c code it shows the Timer_2_Int_Handler, but the _routines.c code is able to use the Get_Acceleration function and that stops the timer and returns the current acceleration, but how can Get_Acceleration work if i don't call Timer_2_Int_Handler in _routines.c.
I hope i was clear in my confusion, sorry if i wasn't.
So in short, do i need to call Timer_2_int_Hanlder in my user_routines.c code, or does the timer do it, and therefore all i need to do is call the get_acceleration?
Thanks for help with that question, and sorry if i made it more confusing then it was.
My other question deals with what analog port the code specifies for the accelerometer. I think it is the first analog port? Also how would I change the accelerometer.c code to change the port?
Thanks (in advance) for helping us out.
Unread 11-02-2005, 23:05
Electrical Engineer
Rookie Year: 1995
Re: Accelerometer Timer Question
So in short, do i need to call Timer_2_int_Hanlder in my user_routines.c code...
Do you have to look at an alarm clock for it to ring? No. It goes off when you tell it to. So does an interrupt... You do not call it.
Mike Betts
As easy as 355/113...
Unread 11-02-2005, 23:14
Ok, thanks, that is what I thought, i just wasn't sure, b/c it was called in _fast.c and that didn't make any sense to me, especially since it is a timer.
Unread 12-02-2005, 01:34
Just to clarify, Timer_2_Int_Handler is called from InterruptHandlerLow which is called from InterruptVectorLow which is automatic.
Example accelerometer code released. Kevin Watson Programming 0 20-01-2005 03:45
Question of the Week!!! (7/19/04) Andy Grady General Forum 23 23-07-2004 13:21
Question of the Week!!! (6/14/04) Andy Grady General Forum 23 01-07-2004 15:54
Timer interrupt hic-cupping - HELP roknjohn Programming 9 15-03-2004 17:56
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
